- Aug 27, 2004
Coming up in a bit this Cold Steel Ultimate Hunter will be transformed with custom Ti slab handles, with a slight modification to them. Note how you can see the blade tang sticking up when the blade is closed, well, the new handles will be made so they neatly cover that over much like the Calypso Jr does when the blade is closed.
The complaint is the handle is too thick for everyday carry. That will change significantly in short order. It will be interesting to see how the weight changes. The knife weighs in at 4.6 ounces as it sits here. You may notice that the thumb stud on this one is different that was a complaint also and I did that before the scans were taken.
I also note that Cold Steel has made some improvements to this model since I bought my first two of these a good while back. These now have some traction grooves along the areas for the index pressure points to improve grip much like the Blade Tech Pro Hunter and Spyderco Ocelot. Also, they have changed blade steel from the AUS8A of the old model to VG-1 in this newer version. I'm not sure if that is a good thing or a bad thing though. I know very little about VG-1 and don't see it in any of my steel charts.
Thanks for looking.
Stay tuned for more.
STR
Thanks for looking.
STR
