Cold Steel Ultimate Hunter Impressions
Just bought a new Cold Steel Ultimate Hunter folding knife because I was looking for a relatively inexpensive but beefy folder. My first impression upon opening the box was that the thing is big. The handle is about the length of my Benchmade 710's and about 4mm thicker. The blade is a bit shorter, but it feels real beefy in the hand. Could be because my latest purchase was a Camillus EDC. The blade is equally beefy with its 4mm thick hollow, sabre ground blade.
Here's Cold Steel's stock picture of it:
csstoreonline_1912_1906431
The finishing on the knife is superb and on par with knives twice expensive as it. The blade has a luminous satin finish that is like the fine satin finish on my SERE 2000. Can't find anything to complain about as far as finish goes. However, the fit is a different story. The problems are largely aesthetic, so it's not a big problem for what I consider a low-mid price production knife. There is a small gap between the handle scales and the lockbar (which I assume is normal), but one side is a little larger than the other. Second, the blade points a little to the right when you look down the spine and similarly when closed. None of those fitting problems should affect performance, though it does look a little funny when the lockbar and blade are pointed in different directions. There is no significant bladeplay in either direction. All my folding knives have a tiiiiny amount of horizontal play that can only be seen when closed because of the scales (as reference points) which is otherwise unnoticeable when open.
The handle is very ergonomic and fits the hand well in any grip. The handle is quite thick and fills the hand. The ricasso doubles as a finger choil as well, allowing for a choked up grip. The pocket clip doesn't really get in the way at all. The thermorun has a rubbery feel to it and is secure. Under the thermorun are thick skeletonized steel liners. These liners are also beefy and look at least 1.5mm thick, each. Very sturdy feel.
The blade, as I mentioned, is beefy. Despite the thick sabre grind, it is quite thin right behind the edge bevel thanks to its deep hollow grind. Comparable if not thinner than that of my Paramilitary which is also 4mm thick stock, though with a full height flat grind and distal taper. The sharpness is also about equal to that of the Paramilitary.
The lockback is very stiff, though I don't have any other large lockbacks to compare it to. One handed opening is very difficult because of the stiff lock. The pivot is also quite tight and the action is very rough, which doesn't help either. Personally not a big problem because I don't plan on using it as an EDC, more of an outdoor or around the house "I'm-not-gonna-do-that-to-my-nicer-knives" knife. Too thick for EDC anyways, in my opinion.
Opening it results in a loud clack of the stiff lock, and closing it gives a similar result. One handed closing is difficult as well, and something I would avoid doing anyways. Close the knife about 3/4 and push a tiny bit more and the blade vigorously snaps closed. Wouldn't want to catch my fingers in there...I'm not very good at closing lockbacks with one hand anyways. Maybe it would be easier for those of you more experienced with them.
Despite these drawbacks, the lock inspires confidence.
Overall the knife definitely looks and feels like it will exceed my needs for a tough folder. It may not look very pretty, but it definitely has a very sturdy feel to it. Stiff lockback, thick liners, thick blade, comfortable and secure handle. Though I have had no experience with the Manix/Mini Manix, I would imagine this knife would be a good alternative at a cheaper price. It is certainly much tougher feeling than the Paramilitary, though admittedly cheaper feeling as well. Great knife at a reasonable price.
-Jon
Is the choil area useful as a grip extension? That knife has recieved similar positive comments in the past. I would be interested in any commentary after you have used it for awhile and can compare it to similar Spyderco's/Benchmade's.
-Cliff
The choil area is larger than they have in their stock photo and works great as a grip extension. It isn't quite as comfortable as the choil on the Paramilitary, but it does its job. Here's a quick photo of the choil area:
There are a couple problems I just noticed. The thermorun is one piece and wraps around the back, so if you ever had to disassemble the knife it looks like it would be a pain. It is also a pain to dry, as I found out after washing it up. The thermorun is flexible, so there are plenty of places for the water to hole up and it took quite a while to get it thoroughly dry. I don't even know if it's completely dry yet. The thumbstuds are also conical, so they are very uncomfortable to use (stiff lock and pointy, slippery studs just don't mix). Still, it's a great knife for the price.
Edit: Apparently there is still some water stuck around the thermorun and lockbar and in the pivot. Will regular tap water rust those parts if it isn't dried out? I can't even get it all out with canned air, and I have no clue when it's going to evaporate on its own. I guess if you wash the knife, use a hair dryer or just wash the blade and try not to get water in the pivot.
The grip texture is good, not too aggressive, but still grippy. The grip also works fine when wet.
Personally, I don't like carrying very large and thick folders because I generally carry in waistband. If you don't really mind carrying something as thick as a small fixed blade, then I see no problems. To give you an idea of the thickness, it is a bit more than 1.5x the width of the Paramilitary. It feels a little heavier than my Paramilitary, but not overweight. The clip works well and isn't too tight or too loose. I don't think it's suitable for EDC, but preferences vary. I would have no problem clipping it to my pocket for a hike or something, though.
Do you have any problem drawing, I would have thought the grip would be a bit sticky in the pocket.
-Cliff
Now that you mention it, yes it does "stick" in your pocket. It still isn't very hard to draw, you just have to pull a little more because it will lift your pants a little before letting go.
I have found that hunting style knives are among the most versatile. They are my favorite designs. I haven't bought a Cold Steel in a loooong time. You have me curious in this model though. Can you post some more pics?
Dennis,
Stick with the Wegners, brother! The BT products are superior in all regards as far as I'm concerned.;)
Regards,
3G
I have had this model for about a year. Although I don't edc it, it has seen time skinning a coyote, camp food prep, and some general tasks. I like the knife except for the clip is, IMHO, poorly designed. Mine has none of the asthetic flaws noted previously, but I have to agree with the lock issues. I originally purchased this knife with the intention of edc because it looks very non-weaponlike. The thickness, feel, and pocket clip put the kibosh on that, but overall I do like the knife.
Dennis,
Regards,
3G
I am with you on that mate: BT or Spyderco versions rule. I have skinned and quartered up to 5 caribou at a time with the C-48 and I have never used it's equal.
C48 at top..other versions here as well, From Top Spyderco's C48 and Ocelot, BT's Mouse Lite/ Hunter Lite and the ProHunter. I still like the C-48 the best.
The ultimate hunter does look pretty good though. Blade shape quite a bit like the Alaskan Bwana which does well.
I will post up some pictures later when I get the chance to take some. As for the aesthetic problems, I could have been sold a factory second without even knowing because it was bought off ebay. I also noticed the satin finish on one side is a little dark (I thought it was just reflection at first), as if it's dirty. I wish there were some way to know whether one was a second or not. Then again, it is a user, so it really isn't a huge deal.
It is a fine knife for the money though. If you're looking for something with a bit thicker stock than a Spyderco in that cost range, then this would be a good choice. I was looking for a knife with 4mm (5/32") stock and no other knife company I can think of offers one at this price.
Biggest complaint I have about this knife so far is the screw design. The lanyard hole is a screw that requires a special tool. I can't describe it, but I will post pictures later. I can't disassemble it without making something to unscrew it, and it is hard to clean and dry if it's together.
I don't own either of those knives, so I really can't say. Judging by their specs though, I'd imagine the Grip and Endura would both be better cutters because they won't bind as much. I'd also imagine both the Grip and Endura would be much easier and more comfortable to carry. I would think the Hunter is a bit tougher, though, since the blade is fairly thick. I would feel comfortable doing some light prying with the Hunter because of the thick build; something I wouldn't really do with the Grip or Endura.
If you don't need a real tough knife, I'd say the Griptillian and Endura are both better, but if you need a beefy sort of knife and don't want to carry a fixed blade, then the Hunter is a good choice.
I have one of these Ultimate Hunters. It is a good value for the bucks spent to get it. Its thermorun handle is tacky and it won't slide on and off the pocket as well as I'd like but its grippy even when wet, and thermorun won't melt from DEET repellents so for an outdoors knife that is a plus for many.
Overall I like the knife a lot. Seems to be up there in lock strength with the best of the best. The blade shape is a great user friendly design. In the end the knife was deemed to big for my EDC rotation but its a well built folder.
STR
