There is not alot of blade there....my question would be, Why?
Zip tie may work, but there is enough spine showing when folded to cut a proper wave hook instead. You can always try the zip tie first and keep it if it works, or wave mod the knife if the zip tie fails.
Unfortunately, you have to do it yourself, it has to be fitted to particular knife. It's not hard to make it, all you need is scrap of aluminium/brass, drill, files and sandpaper.Where can one buy a "surf-up" aftermarket hook like you show in the photo? Google was no help. Thanks.
Can someone post a picture of this zip tie mod or explain it?
ExactlyThanks. It gets captured by the thumb stud and has a rabbet filed into it to register against the spine so it does not rotate when used, right?
