Hello! This is my first post after lurking around for the past couple months or so. The beginning of my interest in axes is probably pretty common. I received several boxes of my grandfather's tools after my parent's cleaned out and sold their house. Behind the decades worth of "what the heck is that" and "who needs this many switch plates" were several axes and hatchets, including the double bit below.
[/URL][/IMG]
After reading several articles on axes and finding this and other forums, I was hooked. I just had to figure out what to do with this hunk of rusty metal. The restoration process has been a great learning experience. I've done a couple things right (I think), and a bunch of things wrong and I couldn't be happier with the process and with how it turned out.
My motivation was to find a way to honor my grandfather by restoring this tool and returning it to working order. From my research, it sounds like painting handles is somewhat controversial
, but I wanted a way of personalizing the restoration. Also, I don't see myself using this axe very often. For one, I just don't have the need. I've been threatened with death by this very axe if I cut down one of my wife's trees! However, I hadn't planned on painting the top next to the head. This was one of my learning moments! In soaking the head in vinegar, I wasn't as careful as necessary in not also soaking the top of the handle. Who knew that the combination of vinegar and steel created a grey-wash stain? Well, I do now!
[/URL][/IMG]
So after two days in the vinegar bath, a couple of days of sanding on the head and using a wire cup, it looks like a different axe. I've read other references to this as opening a present and indeed it was. Before the vinegar bath, there were no embossings visible. I couldn't believe it as the word HOMESTEAD jumped off the steel.
[/URL][/IMG]
After staining the handle and realizing that no amount of stain was covering up my vinegar blunder, I started over by re-sanding the handle and making a new plan. The handle is 32", so from the head down, I did 10" of paint, 10" of stain, and then 12" of paint. I stained it first, doing about 4 coats of minwax antique walnut. Then I did two coats of gesso on the top and bottom, then two coats of white valspar.
[/URL][/IMG]
The striped colors are valspar ruby and cobalt. I am considering burning my grandfather's unit insignia into the handle, the interlocking CY of the 38th Infantry Division "Cyclones", but I'll need a lot more practice with the wood burning tool before I take that leap.
[/URL][/IMG]
I've already started on my next project, a Bingham's Best Brand Hewing Hatchet that came from the same box. I hope to post some pictures of it in the next week or so. Unless my wife takes after me for this new hobby, this will hopefully be the first of many!
--Brent
--Brent
