Color of Sebenzas?
On several of the sites, incl. CR's, I've seen scales appear to be black-or dark charcoal gray in color. Is this just a problem with the photo, or the site itself that it appears in? Is there that much variation in the actual color of the knives?
I would definitely prefer one with the darker color, if there is such an animal. Thanks.
My experience with about 15 or so Sebs is that the scale color doesn't vary significantly. It is probably the variables in the reproduction of the images that make them appear so.
I will advise you that the bead blast scale color CAN be changed, by using different sized beads. The more coarse the finish, the darker the color. This info courtesy of Kit Carson.
I could be wrong ('Im a DOCTOR, Jim, not a physicist'), but I believe this to reflect (pun unintentional) the fact that the light reflected off the scale varys in wavelength with the size of the scattering device(s). In other words, shorter wavelength light is scattered and absorbed by smaller holes and ledges (topographical irregularities), but longer wavelength (darker) light is reflected.
Walt
It also depends on the angle of the lighting, the exposure, and what was done by way of correction or enhancement in image editing afterwards. Abd bead-blasted surfaces are better-behaved for photography or scanning than satin-finish, and satin finish is better-behaved than a high polish.
For example, in this scan of satin-finished Moki knives, the finishing grit lines are positioned at an angle across the light path. If they were parallel to the light path, the blades would come out either glaring-white or nearly black, depending on whether the surface sloped up from the glass away from or toward the "head" of the scanner.
In this scan of some mirror-polished hollow-ground blades, we know the blades don't have that "rainbow-blued" in real life.
In a Sebenza, if the blade is polished and the handle is polished, the grit lines on the handle are lengthwise, and the grit lines on the blade go across. In this scan of a wood-inlay Sebenza, I positioned it to get a decent image of the blade along with a good reproduction of the wood, and so the handle, with the grit lines at only a slight angle to the scanner path, comes out darker than it would if the knife was turned the other way, as in this scan of CGG Sebenzas, where the same surface finish is positioned across the light path. Notice in that picture that the little bits of polished blade surface (the hollow grind, not the stone-washed part) that you can see next to the thumb stud or through the holes in the handles came out an obnoxious glaring white.
Still experimenting . . .
- JKM
www.chaicutlery.com
AKTI Member # SA00001
