Colored epoxy
I remember (not distinctly) reading about do-it-yourself mosaic(?) pins- the kind where you use a brass tube with smaller tubes or rods inside all held together with colored epoxy? Well, what I want to know is, where do I find colored epoxy? The hardware stores in my area haven't even HEARD of it, much less carry it. I suppose I could try to make my own by adding colored inks or some such, but I don't want to blow myself up or turn purple or green.
Thanks, guys.
"The secret to winning any engagement is proper training and superior firepower."
Texas Knifemakers supply.
713-461-8632
they have epoxy colorants
$5.50 for 2oz
white,blue,yellow,black,red,green.
If you have a plastic supply outfit near you they may have colorants for epoxy also.
ED
Hello,
The boat guys know a lot about epoxy.
To color epoxy go to a boat store and look into the West System of epoxies.
Generally you don't tint the epoxy directly, but overcoat it with gelcoat or epoxy paint.
If you are trying to coat small parts, then epoxy paint is what I would use. There is no reason not to tint the base epoxy, and there are colorants to do this. But epoxy paint overcoating is generally easier to mix and use. A full sevice boat store will be able to mix any color you want.
A powder coat, which is heat activated also does the same thing. I use a powder coat epoxy for lures and jigs I make. I get powder coat from http://www.up-north.com/stamina/ .
For real epoxy...
Try www.westmarine.com for source of supply... try www.westsystem.com for information, request their free literature from the web site. West System has a free manual(ask for 002-950) which eplains a lot of things about epoxy.
Various epoxy paints are available. The real epoxy paints(about $20 a quart) are really tough coatings. Much more so than the word paint would suggest.
I use the west system for a lot of things, but I don't make knives, yet.
Bill
K&G finishing supplies (520) 537-o458 sells epoxy colorants, (blue, red,tan, yellow, whit, and black)and they also sell all the parts ou need to make your own moasic pins, brass, copper, and stainless pins and tubes.
Well, for use in mosaic pins you might not want to use standard epoxy collorants, they are quite thick and add to the viscosity of the epoxy, which adds to bubbles ect.
What I have used for mosaic pins, is waterproof caligraphy ink, you can find it in craft stores in lots of colors..
The inks dont make the epoxy thicker, and it actually makes the epoxy dry a little harder, and finishes to a nice high polish..
Another tip, when you go to fill your tubes, get a peice of clear vinyl tubing push it over one end of the pinstock, put the other end into your epoxy and suck the epoxy through like a straw..
This gets it filled without so many bubbles ect...
Hope I could help..
Alan Folts..
I've had good results by adding acrylic paint. Just mixed it in with the resin and added the catalyst. Looked real good and held fine.
Ciao
MM
Christian, I use paint tint from the paint store to color my epoxy. Take a small container and ask the person behind the counter for a couple shots of tint. Dip a tooth pick or screw driver into the colored tint and add it to the epoxy as you mix it up. It does not take very much tint to color the epoxy. Good luck--Ray--
A friend of mine molded a replacement handle for a broken pitcher out of epoxy, in a mold he made out of aluminum foil, and colored the epoxy with food coloring -- it came out transparent and deeply colored like colored glass. (BTW, it came out of the foil mold pretty rough so he had to smooth and polish it with files and sandpaper -- if you want to produce anything in quantity making a smoother mold would save time -- smooth the mold once instead of smoothing each piece. For a one-off, though, the foil mold worked fine.)
I guess you could color epoxy with any kind of pigment or paint or colored ink -- it seems to mix well with anything. Food colorings don't have to be permanent, though, and his handle may fade with time, so I'd rather use permanent colored inks (you can get them in art supply stores). I'm not sure they'd work if you want a really opaque finished product; maybe mixing in a lot of it would make it opaque, or nearly. Or you could try mixing in opaque water colors or maybe oil paint would work better.
I made a gun sight once out of "Miracle Weld," an epoxy putty. It took black magic marker very well (after hardening and shaping) and came out looking like ebony wood more than anything else -- in fact I think you'd have a hard time distinguishing it. Before coloring the stuff was opaque and light gray and it seems to be a bit porous -- the magic marker doesn't rub off like it does on metal.
-Cougar Allen :{)
[This message has been edited by Cougar Allen (edited 01 February 1999).]
I add iron oxide for black epoxy. It bubbles
a bit but when you let it stand for a minute
or two they tend to go away. I use 30 minute
epoxy so it will give me plenty of time to
mix and apply for making mosaic pins. You can get the iron oxide from it ceramic supply stores.
>>DeWayne<<
