The easiest and only way that I know of to get one solid color on Ti is anodizing of the metal. Short of painting the handles that is.
Smith and Wesson manufactured a pistol for years with a "hard anodized" aluminum frame.
The Mod 39 S&W was one of the first modern double action pistols to have an aluminum frame that was made of aluminum and colored "black"
Hard anodizing differs from color anodizing in that the process lays dowm a much thicker coating of anodization.
The material tends to be more scratch resistant, but will still scratch as with all surface colorization.
This is an industrial process that is still widely used today for surface color and protection of different metals.
However the problem lies in finding a company that will do the process for a reasonable fee.
As for disassemble of the blade screws in the handles of the model 42 Bali-Song knives.
This process may be accomplished by the use of an "Arbor Press" with a corresponding punch and die set that will accomidate the handles and the screw size used in the Mod 42.
An arbor press can be obtained that will produce pressures anywhere from 500 pounds to 25 tons and range in price from $100.00 to $18,000.00. Not an investement for everyone
The real expense lies in the punch and die set necessary to remove and reinstall the pins correctly.
The die must hold the handles rigidly in place and support both the bottom side as well as the top side of the handle so that the handle "yoke" will not "splay" apart
The punch must be small enough to fit the screw hole in the screw side of the handles, fit the screw hole in the female part of the blade screw precisely with no lateral movement, be long enough to push the female part of the blade screw completely out of the handle and strong enough to stand the presure that will be place on it from the arbor press, so as to not damage the female part of the blade screw.
The punch and die set will have to be made by a tool and die maker as it is not something that you can go to your neighborhood hardware store and buy.
All in all it can be a very large expenditure of money just to remove the blade screws from the Mod 42 handles without running the risk of danage or total distruction of the knife.
Been there Done that.
Regards To ALL
ChuckG
[This message has been edited by ChuckG (edited 10-05-2000).]
Regards To ALL
ChuckG
