Coming back to Emerson with a CQC-7V
StuntDouble
I've owned a couple of Emersons over the past 10 years or so. Literally a couple, one SOCFK-A and later a CQC-7A. The first was a dud, and I still regret selling the latter. Either way, Emersons started catching my eye again a couple weeks ago. After much hemming and hawing, I finally decided to go with the CQC-7V.
I went with the 7V because I've grown rather fond of tanto shaped blades. I used to buy into the camp that they were only good for "tactical" or combat use, but I'm finding they're my preferred blade shape for everyday use. I like that I have two different straight edges and basically two points with this design.
Anyhow, here's the knife that entered my possession this past Monday.
I was impressed when I removed the knife from its box. The action was stiff, but still smooth, and lockup looked great. Are the edges of the liners still rough? Yes. Do the scales and liners match up perfectly? No. Do I think it matters in actual usage? Not a bit. Really, the only gripe I had about the construction is that the clip side of the knife was a bit higher compared to the pivot side. A quick loosening of the screws, holding everything where it needed to be, and re-tightening fixed the issue. It wasn't something that I could feel when I was holding the knife, but it bugged me enough to want to fix it.
The edge was nicely ground, but it was just too steep to be effective. I like an edge that can cleanly slice paper, so I went to work reprofiling it. After a couple of hours, I finally ended up with an edge was happy with.
I maintained the chisel grind on the edge, and merely extended the bevel a bit. The edge is still plenty strong, but is thin enough to get very sharp. I have no issues slicing paper from either direction now, something that I can't say for the original edge. I'm finding that it performs just as well as a regular V-grind in most of my usage.
The 7V has been in my pocket since I got it Monday, and I honestly don't see it leaving any time soon. It's proven itself capable of doing anything from opening mail to cutting zip-ties. It carries well in the pocket, and the handle fills my grip nicely. I've always liked the more neutral handles of the 7 series, because they lend themselves to a variety of different grips. I don't really use the wave feature all that much, but I find it does work well when I want it to. Now if I could just figure out how to use it to open bottles.....
All in all, I'm glad I finally picked up another Emerson, and I think I might see a couple more in my future.
Have a 7V on the way as well. Used to have a standard years ago and didn't do it for me. The reviews on the V version have been great, so can't wait to give it a shot.
I also took a few comparison shots with the knife that ignited my love for tantos; a Kershaw Tanto Zing.
As much as I like the Zing, the handle always felt a bit small to me. It was fine for normal tasks, but for ones that required a bit more force, I prefer something a bit larger.
One thing I like about the Zing, is the smaller angle of the secondary edge. I kinda wish the CQC-7's point was just a little bit lower than it is now, but it doesn't make that big of a difference.
I was surprised to find that the blades of both knives were pretty much the same thickness. The Zing blade is a lot shorter in height, but it also has a hollow grind, which really helps thin the blade out. The steel also gets a lot thinner toward the tip, making it pointier but less robust than the Emerson design.
As much as I loved that Zing, the 7V has pretty much replaced it in my pocket now. The only time I really see myself carrying the Kershaw over the Emerson is if I'm wearing shorts without a belt. Its lighter weight makes it a little easier to carry in those situations.
Rolf,
Ain't that the truth. I'm already thinking about what my next one will be. The main thing I have to figure out, larger or smaller?
I didn't realize the tan scales were thicker. They definitely have a nice feel, and I was actually surprised to find they didn't have any sharp edges. They're very easy on the hands.
The models with the Tan G10 scales feel great. I really hope Emerson decides to do this thickness and perhaps the texture as well on all their models that have Black G10. At least the thickness. When I received my Tan 7V, I was really surprised with how it felt. So surprised that when I made the orange replacement scales, I emulated the stock style with the addition of the thumb groove to help with thumbdisc openings minus the texture. Been really impressed with the knife in general.
Mine arrived just the other day. Really impressed again with the F/F on mine. Buttery smooth action and tight lockup open and closed. It's a keeper!
It does look pretty sharp with the serrations. My next one may end up being a combo edge.
I actually just sent mine back for a factory resharpening. I kept having issues losing the edge, so I'm thinking I might have taken it down a bit too much. Hopefully they can get it back to where it needs to be.
I actually felt a little sad when I had to put my Kershaw in my pocket this morning.
Sure sounds like you need a backup Emerson for when your #1 is down! :-)
Edit: Correction... I thought you got a SOCFK too recently?
I thinned down the bevel on mine a while back also, but didn't like the way it looked by the sharpening choil/stop pin notch. I sent it out to Chris Berry for a regrind and it came out awesome.
Nah, I had the SOCFK back in 2001. It's funny you mention having a backup though, because I was thinking the same thing. I actually found an SOCFK-B for sale pretty cheap.
Do you know what angle you sharpened at and how fast do you lose the edge? I did my Journeyman at 20° and it slices very well. It will loose its edge faster than mine at the factory angle especially when cutting harder material but if I hit the strop every few days it stays nice and sharp. I haven't had to resharpen it yet with a stone so it isn't too steep. I find that Emerson blades will stay nice and sharp with just an ultra fine ceramic and a strop if I don't let them get too dull.
ETA: Get that SOCFK
