Archer Here
- Nov 2, 2008
ONE OF THIS WEEK’S FEATURED BLADES - Commando Jungle Knife:
Full tang heat treated blade is designed for usage under extreme conditions and is virtually INDESTRUCTIBLE. Extreme Durability Test Video showing this thing chop through Concrete Blocks, even Antler. Then still had an edge to slice through multiple jugs easily.
Shop Details:
1095 High Carbon Steel. Steel is Heat Hardened & quenched. Heat Tempered @ 500 degrees for 2 hours, and letting it air cool.
Measurements:
Total Length = 19 ¼ "
Blade Length = 13 ¾ "
Blade Width = 2 3/8 "
Blade Thickness = 3/16 "
Handle Length = 5 ½ "
Handle Width = 1 ½ "
Handle: Black Linen Micarta
Weight = 1.9 lb
POB = 3” from handle
THIS WEEK’S FEATURED DURABILITY VIDEO: Doomsday Axe #1 - Boarding Axe
Exclusively offered only at the SBG on-line store. Watch professional reviewer Jason Woodard do EXTREME durability tests causing NO damage. Chopping on trees and old tree stumps. Piercing the pointed end easily through water jugs. Chopping completely through 4x4 Pressure-Treated hard wood. Piercing repeatedly through a 55 gallon steel drum. Multiple Tactical Axe Throws into a door. Stabbing both the tip AND broad head of the axe THROUGH THE HOOD OF A CAR multiple times. This is an excellent Tactical Axe design that would be ideal for use by Military, Law Enforcement, and Urban Warfare.
SBG FEATURED BLADE OF THE WEEK: Orc War Cleaver
An SBG Exclusive hand made from start to finish by Scorpion Swords & Knives. Designed for when it gets up close and personal, the design excels at close quarters fighting. For the back serrated edge can be used in all manners of utilitarian ways, and even the pommel, which is an extension of the full tang design can be used to deliver a hideous blow. As with ALL our swords and knives, this blade is EXTREMELY DURABLE and almost indestructible blade.
Shop Details:
Measurements:
Weight = 1.9 lb
