Comments on this sander...
Texas knifemakers supply sells this one: belt sander
Comes with a 1/2 hp motor for $400.
I'm finding out using a hacksaw and files is dang hard work.
The url doesn't go to the page of the sander. Need to go to products, then click on "belt sanding equip". It is model D-5010.
They also have an attachment for a bench grinder for $150. Click on the "multi-tool".
[This message has been edited by exsanguinate (edited 11-19-2000).]
It looks like ther is very little room to work at the contact wheel.
There is only about a 1/2" of space from the edge of the contact wheel and the motor casing. Thats not much room to hold the blade while grinding. Otherwise it looks like a versatile machine.
I would check the return policy before you buy. That way your not stuck with a machine you don't like.
Just check out the recent Grizzly thread, in this forum.
I wouldn't want a grinder that could throw the knife right at my belly. You know in case something slips.
I like mine standing up so when I screw up it throws the knife at my foot. Takes longer to get there. I know that there has been a problem with the Grizzly but at $295 it's still not to bad
Take Care
TJ
I went through all the same problems with getting my Grizzly at my shop in working order, but it was worth the hassles @ $295.00. It works really weel for my needs and will grind more steel than I have energy for
Dave Evans
Tenino, WA
Ex-
I have the grinder that you're talking about...it's a good, serviceable piece of machinery. I've had no problems with it, since I got it last yule, and it tripled my production ability. With that said, there are a few downsides...
I agree that it would be nice if it was more of an upright configuration. I have mine mounted kinda high (tall workbench is all I have), and on the occasions when I suddenly remember that steel gets awful HOT while grinding (or if I just plain screw up and lose my grip), it flings the piece a good eight or ten feet across the shop. Bummer.
The REAL inconvenience, though, is the lack of a workrest. I'm constantly fiddling with it, trying to jury-rig a part that comes standard on most grinders.
On the plus side, again, though, the platen is easy to adjust or remove, to do slack-belt grinding. Tracking is a breeze, too. One word of advice, though, if you decide to go with this one--get the rubber-covered idler pulley. On tighter radiuses, when I use the small end, it bucks mercilessly every time the belt joint comes 'round. So most all of my grinds are done at the big end. Maybe I'm just a screw-up, and that's the way it's supposed to be, but it'd sure be nice to have rubber at the other end, too!
Overall, this is a good grinder to start with. It does enoug--without deluging you with so many gadgets and whatsits--that you can really focus on learning to grind. Once you've learned, though, you may find yourself wishing it had a few extras that come with slightly higher price tags...
BTW, Grizzly didn't start offering theirs until about four months after I got this...or I probably would've gone that way. Cheaper, and if ya cuss it enough, you can make it work...
Saving up for a Hard Core and heading back out to the shop--See ya!
Vaya con Queso!!!
It may be a typo but I see the belts are listed as 2 1/2 x 48. Belts that size wouldn't be too standard. Sear has 2 x 42 with an 8" disk that you may want to look at and it sells for less than the one you are looking at even when it's not on sale. It has no contact wheel but it is 1HP and built solid.
Rob!
Rob Ridley
Ranger Original Handcrafted Knives
Hmmm. Grizzly??
Need I say more?? Well, I actually get to play with it soon, so I will be doing a VERY in depth review of it in the next few days. I'll let you know how it is. Another way is Kovals. They have belt sanders with pulleys for like $200. YOu just need a motor and you can adjsut the speed slightly. Are these any good? Also, for $500, you can get the PRo Cut 2 w/o motor. GOod luck and wait to see how the grizzly is!
PS..does swearing at it really work??
The Sears belts are the ones that aren't standard. The 2 X 48 belts can be had at all of the knife supply houses. That really is a big advantage, belt selection.
The grinder in question is not bad for just getting started. Not bad at all. I personally don't care for the horizontal platen but to each his own. For not much more money, you can get a Coote, for about the same money you can get a Kalamazoo. I have seen some "not too positive" things stated about the Grizzly here of late.
I'm just using 2x48 belts on mine...I do all my grinding from the right, anyway, so I set the tracking to keep the belt on that side, and go to work. My mitts are too big to come at it from the left, since the motor's right there...oh, well. I'm still glad I have it.
Vaya con Queso!!!
