- Dec 11, 2000
Looking at sending some CPM154, Sandvik 12C27 and AEB-L out for heat treating with a professional and was wondering what folk here would think of the process described by this HT service provider?
Oil quenching stainless was talked about here once upon a time, but usually in combination with folk experimenting with torch hardening. Usually 440C.
Do you think the above process provide you with acceptable results?
Thanks
Chris
....we heat treat most grades of steels, both Carbon, Stainless & Damascus....
All heat treatment is effected from a digitally controlled furnace and blades are quenched in our own hybrid system which is a combination of an appropriately formulated mineral quench oil and a quench press designed to virtually eliminate distortion in the blade.
We do not work with a protective atmosphere but instead use anti-scaling paints to reduce decarburisation and minimise scaling. All blades are sand blast cleaned prior to dispatch.
Carbon Steel blades are tempered once and Stainless Steel blades are tempered twice unless otherwise requested.
We do not have liquid nitrogen or dry ice cryogenic facilities. Stainless steel blades are oil quenched and then cooled to -13F for a minimum of 1 hour and our hardening temperatures and times for Stainless Steel blades are optimised to give best results with this level of cooling. We feel that more severe cryogenic treatments for Stainless Steel are only really necessary for air or vacuum quench hardening processes that generate higher levels of retained austenite during the quench.
All blades are hardness tested on the tang and a test certificate will be sent with the blades.
Thanks
Chris
