I'll second that.Don't have a lot of experience with the WWII yet,but Dirtbikers synopsis is correct.The M-43 runs about 4-6 ounces heavier and has a very different feel in hand.Either one will serve well in the field, but neither are lightweights.Personally, I prefer the feel of the WWII,but both are worthy tools without question.I wouldnt say that. The M43 handle is quite long. I also like that the M43 has a smooth handle (no ring).
The M43 is a much heavier chopper, the WWII feels more lively in the hand.
I'm a fan of both so I say get one of each when money allows.
I am learning. The 18" WWII seems to have a (much?) bigger handle than the M43 which would be important to me. Are there other compare and contrast kinds of points about these two Khukuris? Besides the full tang thing?
M43 is a full-wide tang with pins holding two handle scales instead of a single tubular handle with tang through the middle. Given the size and thickness of HI Khukuris, the usual advantage of the full tang over what is often called a stick tang is greatly diminished but just in terms of the physics, a full tang knife will be stronger. It also imparts some shock to the hand and in cold climates, imparts chill to the hand and the hand can freeze to it....witness the fact that ALL scandinavian knives lack a full tang so that the hand touches only warmer wood.
pialia
I just saw you're from Sweden...so I guess you get the Scandinavian knife thing then :thumbup:
I do :>
I have too many Moras to count. Every possible config. In fact, I have plans to take, maybe an M43, doctor up the sheath, and include either a Mora of some sort or maybe an ESEE-3 or Izula in place of the traditional Karda. Just one of my thoughts.
