Comparing Irish Jacks
eisman
Platinum Member
I like the Irish Jack pattern knives. The combination of a long straight blade and a pen secondary works for me. I carry a 2013 Forum knife almost every day. It’s an old, hard to find pattern that’s unique enough to somewhat individualistic.
Until this spring, when GEC finally came around and made some offerings based on the 2013 knife, the only other brand I could find in this pattern (on a realistic price basis) was Fight’n Rooster. Those knives were German made, very well constructed, but done in short runs. Luckily that meant that most were “collected” and not used.
For those who might be interested in the pattern (and those of you just reading along because you have nothing else better to do) I’d like to point out some of the differences and (too me anyways) strong points between the GEC and Roosters of this type.
For this I’m going to use as examples my regular carry (2013), my previous pocket pal (FR), and one of the new GEC Speaker Jacks (SJ).
All three of these knives are the same length, sitting right at 3 5/8” closed. The biggest noticeable difference is that the Fight’n Rooster is both thicker and heavier. This might be just in the scales, but I have a couple of the Roosters in MOP and they also feel the same and those scales are not proud at all.
One of the nice things about having all three together is that you can see the different bolster treatments. The fluted bolsters on the 2013 are nice (better than plain), but I think the threaded bolsters on the SJ look better. The FR would look a lot better (just my opinion) with threaded bolsters like those on the Speaker Jack, in part due to its longer bolsters. By the same token, the GECs could use the polish the FR exhibits. I also like the somewhat deeper angled cut at the end of the bolsters on the FR knife.
Until I started looking at these together I didn’t realize that all three are assembled slightly differently. The FR used German (nickle) silver for the bolsters, and they have that slightly gold sheen to them. I think this looks good with the traditional brass liners. The 2013 is all stainless, and the SJ is stainless with brass liners. I can’t say I have a preference for a specific version based on this, but it’s interesting to see.
It’s the other way around with the blades, those on the FR being a mirror polished stainless, vs the GEC carbon steel. I like the way the character of the blade on the 2013 looks with the ivory scales. But the FR polish has really stood up too, and while not as heavily used, it looks good.
The scales on all three knives are fitted exceptionally well. The FR, being of German manufacture, stands a little thicker than the bolsters and are tapered down to the bolsters, where the GEC knives keep a low, smooth, profile their entire length. I think this smooth contour makes for a very slick, and more refined, profile. The materials on all three have history, and can be expected to last and perform well.
On a side note, the scales for the 2013 were a clearer white, and they have ‘yellowed” over the years like the ivory they were to mimic. It’s not much, but enough to notice. (I have an unused knife to compare to.)
I can’t say I’m perfectly satisfied with the shields on any of these, but it is interesting to see just how different they look. The bar forward on the FR seems unbalanced, where the bar centered on the 2013 just seems to detract from the curves of the frame. I wonder how much better it would look with a slightly curved bar in place? Or perhaps the “Cloud” from the SJ should have been centered?
Going back to the blades, I have to admit I prefer the secondary fitted as on the 2013; in front of, and nicked on the same side as, the primary blade. GEC did this very well, first in relieving the frame to allow access to the low sitting pen blade (nice touch) and using the long pull on the sheepsfoot main. Since the main rides fairly high, and pinching it to open is not difficult, there was no real need for the long pull, but it does look good on these blades.
However, I really prefer the sharper point of the FR main blade. It’s easier to start a cut in a corner with that blade, and it seems to “bite” better in some cuts. It also sets lower in the frame when using the pen blade, and as such it’s more comfortable to use. Which makes me wonder why FR didn’t set the pen down a little more and relieve the frame like GEC has done? And why hasn’t GEC put their Wharncliff main on a “Jack” in this pattern? That would interest me greatly.
One thing I did notice is that the FR has much better finish on the blade stops. The GECs look pretty rough when compared, Perhaps as a result, the blade on the FR seem much more positive both at center stop and fully extended.
Another thing GEC did, which I think shows a lot of class and planning, is the use of spacers to fill in the blade channel to match the blades. It’s a small thing, but it looks right, and most manufacturers miss this.
Last, and I admit I’m picking nits, but why did GEC use brass pins on the SJ. If there’s one visual complaint I have with this knife, it’s that those pins look out of place on the otherwise black and silver profile.
Anyways, there you have it. My $.02 on a few knives I like and carry; even though none are “perfect”. I hope this kept you entertained, and maybe got you to look at some of your knives a little more carefully.
Remember, pointy end forward…
Are you sure the Rooster is stainless? I have/had many and always assumed they were stainless, but found out they were highly polished 1095.
Beautiful knives by the way, one of my favorite patterns as well. A shame GEC put the pen blade on the wrong side with the current run.
^^ Good question. I have several Fight'n Roosters I KNOW have carbon blades. But I'll have to try something other than hitting it with a blue pen, 'cause that didn't take.
Nice analysis of the pattern, Eisman - never knew they were "IRISH" jacks!!
It's a very scarce pattern so it's rewarding to look at the differences in emphasis between the 2 manafacturers. From my point of view, I think the GEC covers the pattern more satisfyingly. I like the wraparound spring, it is an attention to aesthetic detail. The Rat-Tail bolsters on the Forum 13 knife elevate it still higher and I also prefer that the bolsters on the GEC knives are shorter than the German knife's, never been keen on over large bolsters and some German Bökers sport some rather ludicrously large bolsters on their Congress patterns. Having very different Master blades, Sheepfoot/Wharncliffe is interesting too. GEC's Pen version of this 13 frame offers a very long Wharncliffe The GEC knives open out smartly with no blade droop or 'cant' whereas the FR looks less pleasing. I also admire that GEC offers blades on both sides with these Jacks. Convention seems to favour same side nail nicks, but it can present problems in accessing the Master's nick, the cut-out is a quality feature for sure. From a point of view of aesthetics I actually prefer the blades on different sides, after long consideration.
You dislike the use of brass pins on the SJ but it's not really unusual, it has brass liners after all. I'd just like to see a whole lot LESS brass on knives anyway, get steel/stainless or NS liners any day. Are you sure the 13 Forum Knife has stainless bolsters? I thought they were the usual NS but with NS liners & pins- thankfully ....;)
I think the recent GEC 13 did miss out on offering any really interesting jigged bone or a tasteful acrylic for the Jack and Pen versions. I have to say, that the Whittler version left me very cold indeed, not my cup of tea at all. But, this frame still has a lot of potential and I rather regret missing out on a decent SJ version like you show, the shieldless Stags look neutered to my eye.
Thanks very much for the pictures and review, very absorbing.
Regards, Will
Charlie - Remington listed the pattern as an Irish Jack. Way back before our time, so I defer to them. I've only seen one, and it was in such poor shape I couldn't bring myself to buy it.
Will - The main blade on the FR knives tapers all the way back, which I tried to show. Their body also has a bit more curve to it than does the GEC pattern. Those two things do make the blade look a bit "droopy". But I still prefer the ability to stick something with the point. As to the bolsters, the GEC ones don't have the same golden sheen I normally associate with NS. It could be a different alloy, but they match the liners in color, and those are stainless.
I'd really like one of the GEC's in a tortoise shell, and black MOP would be nice too, but I'm patient. It took the 3+ years to step up after our forum knife. I'm not sure what their total run numbers were, but I do know they sold out pretty quick. That should help keep them on the board for a release every couple years.
Great post! Never knew they were called Irish Jacks. Gives me good reason to find one for my dad for Father's Day, he would love that.
I broke my SJ out of the drawer for carry today simply because it hadn't seen much attention in the last few weeks. And tripping across your thread was a happy coincidence. It really is a fantastic pattern. The shield does leave a little to be desired for me as well. The centered cloud on the clerk version looks off to my eye because of the proximity to the middle pin. But a curved shield of some kind would look great and accentuate the curve of the knife. I really wanted to like the whittler version. The shield looked great and that chestnut jigged bone was fantastic. But the double pen killed it for me. Those covers and shield on the SJ would have been a nice combo. But we can't always have everything I understand that.
My only complaint is the walk and talk. On my version it's almost none existent. Blades feel like total mush on closing and the pen occasionally needs some extra assistance to fully close. That doesn't stop me from using it but the lack of a crisp snap either direction does take just that little bit of fun out it for me.
And to add to the naming issue, which, frankly, GEC did not help, I offer these two page shots:
First this one from "Fight'n Rooster Knives"- in which the pattern is called the Irish Congress...
And then this, from Bruce Voyles "Antique Knives" - Where he shows the pattern by Miller knives under the name Congress Jack. Their "Irish Congress" is what is often called the "Half Congress", or, in the new GECspeak, the "Clerk".
Fun review. I personally prefer pen behind the main. Opens cleanly. None of that levering hour thumbnail off of a blade spine to get a blade out because the nick is only partially visible. Yet another reason I love my 77s.
eisman eisman very nice review. The GEC SJ is one of my favorites. I bought two in ebony and gave one to a friend. Thanks for the review and the background info.
I did not know the name of this pattern either! Thanks for the information, it makes me (yet again) regret selling my 2013...
Another look at the Forum 13 Knife. This was a really well finished knife and unusual in its rarity.
And here is its cousin, the GEC 13 Clerk in Pen form single spring, an impressively long Wharncliffe on this knife from 2017. Excellent W&T, satisfying snap.
