- Dec 19, 2014
Within the past few months I have bought two slipjoints that are similar in that they use modern materials and construction methods and they are priced very close to the same.
One of these isn't too difficult to purchase, the Lionsteel 'CK Edition' clip point Shuffler.
The other is a J.E. Made slipjoint
Both use a 'modern' steel for the blade (M390 for the Shuffler and Crucible CPM S35Vn for the J.E. Made) and both have titanium bolsters and liner.
Both have clip point style blades. Both with swedges. Grinds on both are excellent.
The Shuffler I bought has micarta scales while the J.E. Made has G10.
I paid $135 for the J.E. Made knife and $128 for the Shuffler (pretty close to the same, I think)
They aren't the same pattern and the J.E. Made is a bit larger, but they are pretty similar here also.
The J.E. Made has a stonewashed finish (which I like a lot) while the Shuffler has a satin finish.
The Shuffler has long pull nail nick on both sides of the blade (pretty cool) while the J.E. Made knife has a ... not sure what it's called (Scagel slot?). I like it though.
The J.E. Made knife also has a lanyard hole.
Fit and finish on both are excellent, though I think the J.E Made knife edges out the Shuffler by a bit.
They both arrives pretty sharp but I have put my own edge on both. The J.E. Made knife seems to have taken an edge better, but that could be on me.
I think the Shuffler has a lighter pull of the two. I can pinch the Shuffler open but not the J.E. Made knife.
The Shuffler weighs in at 2.2 ounces while the J.E. Made knife is 2.7 ounces.
Centering on both is about perfect to my eyes. I'm an easy grader though.
Both have screw construction. I haven't taken either of these two apart but I have taken the scales off my Lionsteel Roundhead with no problem and I assume the Shuffler would be the same.
If I had to choose just one to keep it would be the J.E. Made knife, easily.
The Shuffler is a fine knife and I am happy with it, but the J.E. Made knife has lots of small things that I like better. Considering that the Shuffler is a production model while the J.E. Made is... I'm not sure really... probably a 'mid-tech', I don't know how fair it is to compare them, but the price is close so I went with it.
The only problem with the J.E. Made knife is it's availability.
If you get a chance to buy or handle one of these J.E. Made knives, I encourage you to do so. You will probably be impressed.
