- May 6, 2012
Some of you fellas have asked/requested things I use a punch blade for its a long list so I'm gonna copy and paste my response to Pertinux I gave a month or so ago and then show a field test.
I guess I just grew up using them. Besides the obvious use, works great making holes in wood, as a scribe, it always seems up on a ladder your drill bit looses its magnet so I've used to start a hole to hold a long screw in place, I've made stuff camping with it ( start a spoon, fishing hooks, bobbers, cedar pipe ) scraping PVC , untying knots ( like a marlin spike), I've used to retro fit things like grommets, core out, make a existing hole bigger, I'm sure the list goes on and on at least for me. I will say the Swiss Army farmer has the best one(IMHO). I find it saves a knife blade for its intended use. I also want to add splinter extracting and blisters.
Some photo comparisons of the two
From top
From bottom
Now the test.
First the leather test, the Case pierced through faster but took longer to make the same size hole as the Vic.
Left hole Case took 34.5 seconds right hole Vic 20.1
Next wood test, I used strapping.
First 3 complete turns
The Vic Farmer removed much more material much more efficiently.
Next how long to go through the strapping.
This is where the Vic excelled,
The Vic 35.2 seconds with ease
The Case 1min 50.4seconds and could not go all the way through, it got bound up.
They are both excellent knives in their own right, and I tend to carry the Case more often then not these days, but the Vic's punch is the better preformer.
The Case is a little longer, but the design of the Vic ( the bend ) makes it more rigid and removes the slag when you are using it.
I hope this answers your questions
Comments and other questions are always welcomed
-Pete
I would also like to add the Vic's design is better suited for untying knots.
And when I was young I had a red alox Vic farmer that was a constant companion (lost it) replaced it with a Vic Rucksack when could not find another Farmer in the mid 90's. Bought a Farmer when I found one in 2004
So I my be a little bias towards the Vic, plus I'm extremely comfortable using it. I feel the Case punch is just not as rugged. Just my opinion and you know what they say about opinions
From top
From bottom
Now the test.
-Pete
