hello,
I am thinking of buying a new compass and need some recommendations.
the following is necessary:
- it should make it possible to take a bearing (so a sighting or mirror system is necessary)
- transparent plate for working on maps
- declination adjustment
- clinometer
- fluid dampened needle
- long ruler for working on maps
- 360 °, not the military 64 scale
It is used for
- teaching (cross bearings, orientation etc.)
- caving (GPS is not an option...)
- hiking in the mountains (mostly alps)
until now I found
1. the Recta DS 56 has a "Global" needle and a "window" in the mirror for the bearings. I heard Recta had/has? some issues with bubbles inside the fluid above 1500 meters (I use the compass in the mountains too)
2. the SILVA Expedition 25 TDCL has electric illumination and there is a special model with a bubble level (what is this for?) - it lacks the "window" so the mark on the mirror and the V-shaped sight are used for the bearing.
3. the ESCHENBACH Alpin. I do not really know the company, but it looks similar to the RECTA - just without the global system.
Do you know any of these or other good compasses and can recommend one? I find the Recta looks good, but I do not like the "bubbles"-rumor...
Thank you in advance
Andreas
- clinometer
It is used for
until now I found
Andreas
