- Feb 27, 2011
Hey peoples,
I decided to post some comprehensive, deep questions.
My area's knife laws are annoying.. The laws only speak against concealed carry, and then at school grounds, gov buildings, etc. This, I presume, means open-carry. I'd really appreciate the opinions of police, especially in the eastern coastal states. Also, there is the consideration of "visibility", appearance and image, size, length, cutting-edge length, and the like. Let's say for example, you EDC a knife, a fixed-blade, and an officer is looking at you from your left side (left hip/side visible), but your knife is on your right side/hip, is that considered concealed? Also, what would dictate an intimdating knife? (For me, in my own opinion, it would be something which is obviously quick-access, clip-point, with no retention-straps or clips, all black--handle/sheath/blade--or a dagger. Blade-length, anything six or above gives me pause.) What would dictate a dangerous knife? (again, in my opinion, the above). Also, does the image of the knife have anything to do with it. Say, for example, a knife that is CLEARLY expensive, well-cared for, and attractively built -- say, a good kydex sheath with white micarta scales.
*Also, in my own opinion, I'm more wary, personally, of folding knives..though, only the fast-opening "assisted" variety..now those things scare the living hell out of me. Atleast with a FB you can see the thing!! I'd presume Cops are more wary of them as well? Regular one-handers don't bother me..but those assisted do.
Also, other questions, my work--being professional Woodsman (-_- Yes, a lumberjack.., but I've also got quite a few other skills too which deal with the Outdoors, so Woodsman
) my work DOES require the use of edged-tools..well, besides an axe and chainsaw. I've often needed a knife in my work, and while my multitool has often sufficed, there have been times a tough fixed-blade would have been nice. Often enough, I use a knife to mark a tree, to mark the prefered impact of my first swings. Also, my work is dangerous in the extreme...falling trees, axes, roots to trip over, and chainsaws...not to mention bears and snakes. Does this provide a viable, understandable reason for the tool on hand? (If anyone is curious, yea, I've gotten hurt at work quite a few times.. Nearly chopped off a toe, knocked on the head by debrie from limbs, cut, slashed, etc lol.) Yeah...roots plus chainsaw plus falling tree......fun times.
Another consideration, the knife's retention. If it absolutely REQUIRES two-hands to deploy, and by this I mean that the tension must be adjusted to allow it to be drawn, and then two or more straps undone, and pressure placed on the sheath by the other hand just to deploy the knife. Also, a small tool would likely be required to pull it free.
Also, does the sheath need to be seen, or merely the handle. Does it matter how it is worn, so long as the handle is visible? May the knife be worn in a wallet-like sheath, so long as the handle is clearly visible, and tightly retained. *That gave me a new sheath idea..although, it'd likely backfire on me...last one did...badly burned hands from kydex.
Lastly, if a state has a 4 in or 3 in or such and such limit, does a quarter or half over count? Would it really make that much of a difference?
Thanks in advance, and an extra thank you to any LEOs.
*Got a splitting headache from re-typing this.
**And a big thank you to all LEOs for your service.
***Wrote this out as best I could. Gimme a break, I'm sick as a dog--flu.
