- Oct 5, 2005
Lil' Temperance (Trailing Point) (2001)
Extremely strong tension on the lock bar (intentional as this is an MBC / self-defense knife where a strong, no-fail lockup is necessary). No detent ball, but instead a channel is cut out of the blade that the lock bar rides against. No vertical or horizontal play. Paper thin orange washers (some type of nylon?). Pretty smooth to open with strong closed retention (that extra tension in the lock bar). Kinda sticky lockup, but I never gave the knife a chance to fully break in.
Spyderco Paramilitary (CPM-D2 sprint run) (2006-ish)
Very slight amount of vertical play but no effect on lock function. Again - no ball detent, but again a channel is cut into the side of the blade that the lock bar rides against. Bronze washers, extremely butter-smooth to open and close (thanks pivot bushing!). Great detent. Occational sticky lockup, but never used the knife enough to have it fully break in.
Spyderco Superleaf (2011/2012)
My newest Compression lock and by far the best example of the three I've owned over the years. Silky smooth to open and close (thick nylon washers and detent ball facilitate this). Excellent blade retention, Rock solid lockup - no play in any direction. The lock swings open and closed with the most minimal of wrist action, even with the pivot Loctited and dialed-in. This one is sitting in my pocket as I type and is incredibly addicting to open/close during my morning commute (I get a whole hour to tinker with sharp objects while driving - 2 hours total if you count the drive home!)
The Compression lock is becoming one of my favorites because of it's overall robustness and lack of extraneous moving parts in comparison to a lot of different locking mechanisms on the market right now. Wedging the lock bar between the lock face and stop pin was a brilliant idea by Sal. Very well-engineered design, as its simplicity is deceiving - the tolerances and fitting are crucial to making the lock function correctly.
Both the 1st gen Paramilitary and the Lil' Temperance have both moved on to better homes, but for reasons other than the locking mechanism.
I see a lot of Paramilitary 2 love both here and on other knife forums. I haven't had the pleasure of using one yet, but the Compression lock finally seems to be making a very positive impression on mainstream knife users.
The upcoming integral Ti Compression lock on the Paramilitary 2 is going to be a big hit.
Your thoughts?
Your thoughts?
