Compression Lock my Favorite and How to Open it! with Pics
My favorite lock with no obvious disadvantages. Every other lock has at least one potential fault IMO. For a lefty it is much more awkward but I'm not so...
First off I wont say this will work for everyone but it's how I do it and to me it's very natural. Thanks for looking.
It's a good method. My favorite, at least for knives with a kick, is to hold the knife normally, then bring your thumb back and press the tab. For non-Gunting knives, you press the tab and the left liner between thumb and forefinger. for the Gunting, you simply press your thunb to the right (slightly harder, since there's less counterpressure). The kick will fall on your index finger, then you withdraw your fingers, rotate the knife, and press the blade home with your fingers on the outside of the blade.
This works well for all knives with a back lock, but it does pose the possibility that the blade will scrape your fingers as you withdraw them. If you're careful, this possibility is very remote.
For the Lil' T, the method you illustrate looks very safe. Lemme get my Salsa and try it...
... chalk up one more way to easily close a Compression lock!
Just make sure that you aren't pressing on the blade before fully disengaging the compression lock, or you'll put undue wear and tear on the tab.
I don't own a compression lock, but out of curiosity checked out this thread.
Roguesoul-I have to ask you man, what make and model of camera did you use to take those pictures? I can't get over how sharp and detailed they are!
Thanks-
Mongrel
Mongrel Exactly why I started this thread. After reading comments from people who were handling the knife for short periods and maybe not getting the hang of it. I know I've handled knives and decided right then on the spot not to buy it, not love at first sight, so to speak.With the pictures a person can see how easy it is, I use the pictures also because my use of language isn't up to the task of properly describing the action.
The camera is a Kodak DC3400, if I had to do it over I would get one that takes close-ups better, like the one in this thread....
http://www.bladeforums.com/forums/showthread.php?s=&threadid=202801
BRAM Yes the fingers are never in the path of the blade, like they are with a liner lock.
Thanks for the kind words :) :) :)
I really like my Vesuvius. I just figured I was closing/opening my wrong, because I have never been "pinched" by the lock. I've read some threads were a few people got "pinched". Maybe some compression locks have a better chance then others of getting ya. No telling, but I haven't had any problems with my Vesuvius. :)
Blades
Blades I've been pinched by them but it's not even mentionable because it doesn't hurt and it never left a mark, even in the slightest. It's also never prevented the lock from engaging but it does seem like it could be easily remedied by Spyderco if they choose to do it.
Roguesoul,
Does it pinch you on the opening or closing?? Just wondering.
Blades
Blades, sometimes it will pinch you during opening, but only when you first get one. You will instinctivly learn how to avoid this. At any rate, it has never caused me any pain or even marks.
To close my L'il T I just move my grip up onto the scales and pinch the lock between my index finger and thumb. Then I can either close it against my leg or just flick it closed. Simple as pie!
If you haven't tried a compresion lock yet you really should. It's got to be one of the best locks yet devised! :)
Blades The occasional pinch occurs as the lock engages, when opening the knife. In this picture you see the spot on my finger which receives the pinch. The lock pinches between the points of the arrow. Again not an issue with me but now people must judge for themselves.
