Computer CPU help?
I am attempting to replace the Intel Celery CPU with a Pentium 4, but when I install the new CPU and try to boot-up, I just get some kind of "siren" going off, and nothing happens.
By "siren", I'm talking about something that almost sounds like a car alarm, but not nearly as loud.
My motherboard supports the Pentium 4 w/ HT, which is what this CPU supposedly is, so I'm at a loss.
I did buy the CPU used from someone who upgraded their Dell system, but I saw the CPU running fine in their system before I bought it.
Any idea what the problem might be or what I might try?
TIA
Do you have the manual for your mobo? The "siren" is usually a series of beeps telling you which "something" is wrong. The error codes are listed in the manual. Did you triple-check all of the jumper settings on the board to be sure they're right for your CPU?
J-
sometimes those are soft settings in the BIOS
can you get to the BIOS setup?
if it sounds like a car siren going off, most likely the chip is overheating. Do you have a heat sink attached to it? If not, it needs one. And, if so, they work much better with a product like Arctic Silver. You can get it, or something like it, at your local Circuit City, CompUSA, etc. for 5 to 10 bucks.
These are not beeps like you would usually hear. This is more like a theft alarm...is you can imagine that.
I can't get to the bios setup, nothing at all. Just starts whooping, and that's it.
Yes, I have a heat sink and fan directly attached to it.
I put my celery back in and did not bother to attach the heat sink/fan, and it shutdown ASAP, within like 4 seconds. I touched the chip, and it was extremely hot. This was my celery though, not the new P4.
Are the voltage settings correct? How about any clock frequencies?
The alarm you hear is probably voltage induced overheating or possibly a frequency setting that is way out of whack.
TIA
So is your machine a Dell? They way I read this, the P4 chip is out of a Dell...is that correct? The Intel mobo/processors for Dells are proprietary unless they've changed something recently! You can't even plug an ATX power supply into a Dell mobo! If you're lucky...nothing will happen but usually some smoke starts to escape from vital components :eek: .
Bottom line is that if you are trying to put a proprietary processor into a non-proprietary mobo...even if it is the same brand...it might not work out.
John
Never had much luck myself with working with Dell stuff..:grumpy:
What system/mobo do you have?
Keep a close eye on your CPU temps.
Heat is the life shortener and killer.
I have an XP2800+ that set the siren off at 91c under full load...:mad:
Heat sink looks good on mine but I got fluctuating FSB...:confused:
No, my machine is not a Dell. Are you serious? How do you make a proprietary CPU? I don't really doubt it, as I had heard this type of stuff about Dell before, but I just can't imagine how it's done.
John
I'm afraid so. Don't get me wrong......Dell seems to make some good stuff...but...
I have a Dell Dimension Pentium III 733Mhz and I wanted to upgrade the video card a few years ago so I thought I'd beef up the power supply I got at a good deal (Antec). I removed the old one and plugged the new one up and nothing happened...which was a good thing! Put the orginal power supply back in and the original video card back in and it fired right up. Worked fine. I did a little research and found out then that they were proprietary. They use the standard ATX connections but the main connection to the mobo pin-out is different! You can buy adapters that go between the power supply connector and the mobo to get you by from what I read. These were Intel mobo/processor combos. I've had no problem with RAM, hard drives, CD/DVD drives swapping out...just the powersupply. I would almost bet money that is your problem.
Dell is now offering AMD chips as well. I would imagine they have some kind of agreemet with AMD also. I guess they do that so you have to order replacement parts from them instead of any other computer part supplier?
I needed a machine a few years ago for my wife and needed it fast. I bought her an eMachine because I couldn't build one that cheap for just the tasks she needed to perform on it. I went with an eMachine because it is true ATX form factor when it comes to swapping out all parts. They may have a mobo that is only sold to them but that might be it. I think just about all the manufacturers are getting back to standard form factor equipment because people were avoiding the proprietary thing.
I would look into buying a mobo/processor combo if you are wanting to upgrade. Especially if your RAM is compatible with the new mobo. I think I like the AMD chips as well. I've had Intel and AMD machines side by side with very similar specs doing a zero routine on the hard drives and format/OS install at the same times. The AMD box left the Intel box behind when it came to downloading and processing the Microsoft updates for XP. I know they both have their good and bad points but I would avoid anything proprietary.
John
