- Nov 12, 2020
This is my first post here and my first foray into making a blade. I use blade very loosely, I am making letter openers. This way I can dip my toes in without having to figure out heat treating.
Short version:
What is the best way to secure a 3mm copper rod inside of a 5/32" tube (1/8" ID)?
Long version:
The letter opener I made was intended to use 1/8" brass pins cut from a standard brass rod. Technically it was supposed to use 3mm brass pins, but my only 3mm bit broke and I couldn't locally source a 3mm bit. I don't have a drill press and drilled one of the holes out of square. It was far enough out that the scale broke when I tried to fit it in.
To fix the problem I decided to re-drill the hole to 5/32" and use a brass rod with a 3mm copper rod. The ID of the rod is 1/8" (3.2 mm). I used two-part epoxy (Gorilla Glue brand) and did my best to coat the pin. I made up the pins before inserting them into the tang. This part went as expected. However, when I went to file down the pins flush with the scales, one of the pins came loose from the outer rod. Since the outer part was already epoxied and I didn't want to start over I just used a roll-pin punch to try and peen out the copper. I was still about 1/16 proud of the scale surface. I was able to complete the filing and sanding process without the pin coming out. I just don't know how stable it will be moving forward.
Is there a better way than epoxy to secure the pin inside of the rod? I contemplated CA glue, but I felt the heat from the cut-off wheel and filing would break the bond.
Short version:
Long version:
