Condor Aqualore
Bearzilla911
Been testing the Condor Aqualore out. It is an excellent bushcrafting option. Specs below from online. The grind came nice and even with a sharp edge and it polished up nicely. The scandi grind bites into wood like one would expect, very well, ha.
  • Blade Length: 4.31" (109.5 mm)
  • Handle Length: 5.01" (127.0 mm)
  • Overall Length: 9.32" (236.5 mm)
  • Blade Material: Sandvik 14C28N Stainless Steel
  • Blade Thickness: 0.12" (3.0 mm)
  • Blade Style: Drop Point
  • Blade Grind: Scandi
  • Blade Finish: Blasted Satin
  • Handle Material: Blue Micarta
  • Sheath Material: MOLLE Compatible Kydex
  • Weight: 9.88 oz. (280.0 g)
I love that it is stainless for wet environments and I understand 14C28N is pretty tough. I have Mora Garberg with the same steel. The handle on this knife is very comfortable. Seems like most of the Condor knives are made with carbon steels (1075 or 1095); I have a number of them, so it is nice to have the stainless option. After making feathersticks and some batoning (probably about 15 of the size pieces shown below), a little stropping took it right back to razor sharp.
The sheath, which is kydex, has nice retention and very comfortable thumb push.
