Condor Final Frontier Knife - two week review.
I have owned this knife now for right around two weeks and have already found a few modifications that make it near perfect for under $60.
Here is the knife with no modifications, stock from Condor.
These first two are just to show the high quality leather sheath everyone has come to expect with Condor knives. The attachment point feels solid and it even has a piece of leather glued over the rivet on the interior to keep it from rubbing the blade. The same as with all other Condor sheaths I have seen, there is no drainage point in the bottom so you will have to make your own if you need it.
The next pictures show the full scandi ground blade which I have removed the back coating from and given a forced vinegar patina to protect from rust. The blade is made from 1075 high carbon steel and is 4" long with jimping on the back. I do have to comment that I found quite a few marks on the blade after removing the black coating. I know this is commonly why the coating is used and it does not affect the performance but it does take away a few points for fit and finish.
The handle has three aluminum tube pins for lashing to use as a spear or to wrap with spare cord. I would prefer brass but it isn't a deal breaker. As to the micarta scales I found no gaps, rough edges, or hot spots so those get an A in my book.
I took a file and squared the back edge more to throw sparks as the original had rounded edges that made it hard to strike a fire steel.
These pictures give you a comparison in size to a Leatherman Super Tool 300 and a Condor Bushlore and the second picture shows that it is actually a little thinner in hand than the Bushlore which isn't a problem as I have fairly large hands and it is still a solid fit.
The welded on butt cap which works well for hammering with or on depending on your needs. It is solidly affixed and I had no issues hammering it into a 2X4 and also using it to hammer with.
This is the bow drill socket which to be honest I have not tested yet but will try to on my next outing.
All in all I would rate it as well worth the $55 dollars I spent on it and would recommend it to anyone looking for a good all around knife that won't break the bank.
One thing to note is that (as can be seen in your photos) Condor's stock photo is incorrect. The edge does not extend all the way to the base of the blade, and a small ricasso is present.
I was looking at these, but I'm going for the $60 Becker BK5 first then it will be between this and the new Buck bushcrafter. Tough choices lol
Thank you for the correction, I actually didn't even notice that in the stock photo. I would have more "in action" photos but my phone decided to go fro a swim.
I just received this knife, and I must say, I like it! My impressions- I am extremely pleased with the length, geometry and especially the thickness of this blade. It bucks the current trend of too thick knives which only excel at batoning too large of kindling but are useless and clumsy at every other task . 3 mm instead of the common 4 mm thickness, thick enough to be plenty strong, but not over thick. It has a nice grip and due to the ergonomics and length of the handle gives a good sense of safety and non slippage of the hand onto the blade. The handle is definitely long, and would be appreciated by those with large hands (which I do not have) but due to the placement of the swell, is very comfortable in the hand. The long handle makes it nice in a gloved hand, important here in the cold wilds of Manitoba. The grip is good when wet. It feather sticks absolutely effortlessly. It has a good stout pointy tip.The pommel is great and would crack acorn shells well, lol. I could definitely hammer a nail in with it, which is kind of cool. It's a high carbon steel that throws sparks. One drawback is for some reason the spine is slightly rounded, which I don't understand but that's easily fixed. I don't like the black coating but that's easily fixed. It batons thick branches and small tree trunks nicely,and why would you need anything thicker for kindling? It also meets my needs very nicely as a one knife only knife in that it does alot of bushcraft work nicely but also serves quite well as a bush food prep knife- I can dice with it. It has a nice angle of scandi grind, not too chunky making it only good for woodwork, but a good all around grind, i might convex it, but that's a personal preference. As with all condor knives, it comes with a nice, attractive thick leather sheath, and as with all condor knives (in my opinion) the sheath sits too high on the hip. I added a dangler and it's great, again personal preference. I appreciate that 1075 should be a good tough steel, especially in the Manitoba cold, but I hope it keeps an edge well, haven't had it long enough to know yet. It's light (but not too light) and nimble in the hand. All in all a pretty sweet deal for the price, I'll get back to you about the edge holding! Pretty good so far though.
Bringing this one back for a reboot.
I just received my CFF yesterday and it's even better than expected (and outstanding for the price I paid on a Groupon deal). I think the size is great...thickness, blade, and handle. I have a Bushcraft Basic 4" that's great, but this CFF feels just right. Love the micarta scales, welded butt plate, & the blade is razor sharp. I think I'll likely ditch the coating and either leave it polished or might try a patina/etched finish. The sheath is top quality & nice and snug with a nice bit of the handle accessible. I think it'll be my go to blade for quite a while.
I'm thinking of picking one up and grinding the corner off the spine into a more parabolic Woodlore style shape
You might hurry on buying the BK5. I believe they were discontinued like the BK15 was a while back.
