- Aug 9, 2005
Received my Condor Golok Friday after an agonizing week of waiting
. I haven't been so excited about a blade in forever. Unfortunately it isn't what I'm looking for, but here are my thoughts.
:thumbup: The Good:
Fit-and-finish is excellent. The black coating on the blade is evenly applied, bevels are highly polished, profile is likewise clean and even without any noticeable dips/bumps. There's a nice "CONDOR" logo etched/stamped into the spine above the ricasso. The handle scales are evenly shaped and thick; too thick for me, but better that than too thin. The "ball" of the handle is a superb feature, it locks your hand in and is very comfortable. Heat treatments seems to be very good after a bit of testing. Overall a very nice package.
:thumbdn: The Bad:
The bevels are not evenly ground, both left-to-right and profile-wise. If you hold the blade sideways so that the edge and spine are horizontal in the same plane, you can see dips in the edge. Functionally, it's not a big deal and eventually those waves will sharpen out, but I noticed.
My Subjective Experience:
I received the blade Friday about noon and proceeded to cut grasses, saplings, and chop wrist-thick dry cherry branches. After about 30 minutes I decided I had to do something about the handle, so I spent the rest of the afternoon rasping, sanding, and oiling the handle. Much better!
I didn't find my first day's chopping encouraging. The golok is well balanced, but IMHO too well balanced. Considering its size and weight I thought its chopping power should be greater. So much of that weight is in the handle it makes the golok agile, but hit a bit light for a 14" blade. The other part of this is the grind, which does indeed prevent wedging, but at the cost of penetration. I found the golok prone to glancing even after an hour sharpening on the waterstones. Certainly my technique is not flawless, but I don't have this problem with any of my other blades; though to be fair the next largest knife I own has a 10" blade. Last night I was considering taking the blade to the belt grinder and giving it a convex sabre grind. However that would mean lightening the handle area as well, which I wanted to do anyway, but was unsure if I wanted to dive into that process so soon. I thought I would give the golok a chance to prove itself, and perhaps after a few hours of use I would come to appreciate it for what it was.
Today I took the golok out and chopped for about 10 minutes on some cherry and acacia before I felt something poke me in the hand. The first pin had worked itself out the right side about 1/4"! I went back to the garage and drifted out the pin easily. I tried the other two pins and they also drifted out with little effort. At this point I could lift the front of the scales a bit, so I knew they weren't glued well, and went ahead and drilled out the lanyard tube. The scales were glued well back at the ball, and I had to slide a putty knife under the scales to separate them. Everything came apart cleanly except for the lanyard tube.
The tang is indeed skeletonized, but more material could be removed and I figured this was as good a time as any. However it seems the tang is also hardened and I couldn't get any drill bits to bite. No problem, I have a diamond blade for my hacksaw, it'll just take longer.
But then I sat to ponder. Is it worthwhile for me to invest who knows how many hours of work in an effort to make the golok into something it isn't? Seems to me like a false economy. But I do have a much clearer idea of what I'm looking for in a woods knife of this size, so I consider it a learning experience. Condor makes a good product (adhesive application aside), it simply isn't the type of product that I'm looking for.
And so, the search for my perfect blade continues.
:thumbup: The Good:
:thumbdn: The Bad:
