- Feb 5, 2013
We have a HF 4x6 bandsaw at our community shop but the blades are always trashed, time to buy my own and hoard it.
I'm looking at diemaster II bi-metal blades due to many recommendations I saw here, just not entirely sure which.
I will mostly use it to cut blades out of 1084 and 1080+ bar stock - have some in .110, .125, and .1375 thickness. I know about 3 teeth in the cut (with 2-10 OK, according to some), which suggests the 24tpi, but I haven't found lenox bi-metal blades that pitch. I also do see myself cutting some 1/4 and 1/2" mild steel bar stock and some 1.25" cold rolled 1018 round bar in the near future (sooner than I can really afford a second blade).
Can I cut both ends of that range with one blade? I don't care if it takes forever to make the larger cuts, just don't want to ruin the blade.
I'd also like to cut tighter curves with fewer relief cuts when cutting out profiles, so width and thickness come into play. I don't have any sense of how much a narrower or thinner blade reduces blade life, which is why I assume they aren't the first choice.
So, for example, would you suggest
3/8 x .025 10/14
3/8 x .025 14/18
1/2 x .025 14/18
1/2 x .020 24 skip tooth
1/2 x .035 14 skip
(aren't skip tooth only for softer materials? must be tiny, cause that would be the same tooth size as a 48 tip non-skip, right?)
This is purely hobby stuff, doesn't matter if the cuts take forever, especially the thicker ones where it's just gravity fed and needs touching with a candle - or a real cutting fluid if you say it is worth it.
Enco has high carbon blades for $7-8 delivered right now, thanks to the sale. SHould I just buy a coarser high carbon for the small about of thicker stock I'll cut before I can buy a second, coarser bi-metal?
Thanks for any advice,
Fitzhugh
3/8 x .025 10/14
3/8 x .025 14/18
1/2 x .025 14/18
1/2 x .035 14 skip
Fitzhugh
