Congress Tools Sic Stones. Anything I need to know?
Steel130
I ordered these two days ago. Is there any specific details or tips I need to know? I can freehand sharpen. I just haven't used these kind of stones before.
thanks
The 400grit seems to be fine. The 600 grit is really soft and makes a lot of swarf unless you do trailing edge strokes only:
The 600grit is 30µ, the 400grit is 40µ.
I find that using the 600 grit stone dry solves the "too soft" problem. My 600 grit moldmaster is pretty glazed now and really polishes(used dry).
But does it cut very well? I have one of CKTG's 30µ diamond plate stones as a replacement for the Congress Tools stone, so I don't use it any more, but if it works as a finer micron polishing stone when dry, I might try it again.
Yes, it cuts well but I don't have any experience with the diamond plate so I can't compare them. It works better than the 1K stock EP stone for me as a polishing stone when used dry.
I got the stones in today. Been messing around on a few knives. Getting the hand more of free hand sharpening. While I had successfully sharpened up a few of my knives free hand on sharpmaker rods. Its taking abit more concentration. I also have a bit more trouble removing burrs when freehaninding. The 400 grit seems really low for me to leave as my finished edge. So I have been taking it to a Spyderco Fine stone after, and then stropping.
The 400 grit stone gives a med aggressive edge finish.
Ok. It did seem about like what the Spyderco medium stone was? Not sure. It was cutting great, that I realized.
I find the 400 grit moldmaster to be much coarser than spyderco medium. Spyderco medium seems to be around a 600 grit scratch pattern for me.
Ok, thats good to know. Because I finished off the edge on it. And had a hard time just push cutting phone book paper. I could easily slice it in all directions though.
After I use the MM 400, I use the 30µ diamond plate from CKTG, EP 400, 600, and sometimes the 1000. The Mold Master 400 is far from finished unless you want a really toothy edge.
What stone do you use to set your bevel? I use the 240 moldmaster and I can push cut phonebook paper pretty easy after I take of the burr on the 240.
BTW, this is the finish I get with 600 grit moldmaster used dry. I did this yesterday morning.
I was using the 400 MM to set the bevel, and Spyderco Fine to finish. I just need more practice it appears haha.
I find that the moldmasters cut very cleanly and give me a much crisper edge. Compared to the stock EP stones, the moldmaster leaves a smaller burr and I do find that it's easier to take off what burr there is with very light edge leading, heel to tip strokes.
PS: If you were using the 400 grit stone to set the bevel, did you get a burr all along the edge?
So do you generally sharpen on these stones edge trailing? Because I was going edge leading. I was also applying water every 5 minutes or so. Maybe more ofter then that.
I use back and forth strokes when I'm hogging off metal and when I go higher grit to get the scratch pattern off of the previous grit. When I take of the burr and refine the edge, I only do edge leading. Except if I use the tapes, then I use edge trailing. I also use glass cleaner to lube the stones which I find keeps them cleaner than using soapy water.
Thanks for the tips. I messed with them more last night. The free handing is taking practice :D.
