- Jan 15, 2007
About a year ago I was able to get a 5# Collins Rafting Axe head. I dressed and refinished the head. I installed a 36" straight handle on it, intending to use at as a splitting axe. It is a big disappointment as a splitting axe. It penetrates well and will stick very tightly in most any wet/green wood. It will split seasoned wood fairly well but most any other axe will also. In addition to its propensity for sticking, it also feels a little clumsy with its poll heavy balance when attempting a split. It naturally lends to splitting with a twist but since it so readily sticks, this potential is negated ... it also tends to over rotate the twist-- if it doesn't stick -- or before it gets enough penetration. Now conversely it feels very stable when pounding with the poll; but the bit side becomes a real limiting factor in the overall usage of it. Part of it could be me getting used to an axe that balances completely differently from any other one I have. But seriously, I have more control and precision with a 6# axe-eye handled maul then with this thing. It is currently my most useless piece of hickory and steel.
My current thinking in re-purposing it is to make this a builder's axe since I have 2 faller's and I don't see a need for a 5# wedge driver. I'm thinking that shortening the handle to 28-30" will also help to better control the head. I hate to remove a perfectly good handle until I at least test its performance and bit control with a shorter handle by cutting off some length. I realize that shortening the handle does not change the head balance but choking up on the grip could give the better bit control that is needed.
Any suggestions?
Any suggestions?
