Hey guys, still using my discount NKH import kukiri,...
Ive noticed that the whole time Ive been using it, Ive been pitting the tip, and getting small nicks.
After I sharpened up the blade to where I wanted it, I cut down several one and a half inch thick trees, and now I have a very serious 1/16 inch deep, quarter inch long nick in the tip.
I anticipate having to put a new edge on with a courser sandpaper, and my mouse pad.
Why is the Tip so much weaker than the sweet spot?
Is this a problem with a Nepalese kukuri's zone hardening, a problem with using a British Service type geometry for heavy work...
or a problem with buying a 70 dollar production model from NKH?
Well first of all Empire_ian, let me welcome you to the HI Forums.:thumbup:
I'm sure what the rest of the guys here told you is spot on but I'd like to ask a couple/few questions and maybe add something from a different perspective.
You say you've been, "Pitting the tip and getting small nicks."
If you are actually getting "pits" that means there will be very small pieces of steel broken off the edge...
The "small nicks" should be small areas where there are still small bits of steel raised up away from the surface of the edge.
These "small nicks" can be pushed back into place with the chakma or in the case of a large one gently tapped back into place with a hammer. Empire_ian your serious nick can possibly be done this way... Like most of the guys say, "We just ignore them." simply because they cause no harm, just don't look pretty.
You ask, "
Why is the Tip so much weaker than the sweet spot?" Well Empire_ian it's not that the tips are "Weaker" so to speak, it's because they are, "Softer."
And it's not, "
a problem with a Nepalese kukuri's zone hardening." as you asked but it is done on purpose as has been explained by some of the other guys that have answered.
But to add my "quarter's worth," The tip is left softer so as to not "Chip/Break" small pieces of steel off that go flying every which way possibly hitting the user in the eye or other very vulnerable place which could cause very serious injury...
Empire_ian you said, "
I anticipate having to put a new edge on with a courser sandpaper, and my mouse pad."
And that could be just what you need to do. Even though a kukuri's edge is almost always convex which is the strongest edge that can be put on a knife there's convex, and there's convex...
Yup, it can be confusing...
The problem is getting too thin of a convex edge on a chopping instrument like a kukri... Naturally a too thin convex edge is going to be weaker than a thicker convex edge...
The trick is to figure out which convex edge is best for you and the flora in your neighborhood...:thumbup:
A heavier/thicker convex edge can be put on by raising the spine of your blade to a steeper angle, helluvit is if you go too thick your kukuri won't chop effectively.
Just remember, Moderation pays off in all things...
