OK-Now that i know what you're asking, I can help!
To "true" a wheel, this is what I do"
Use 120 grit Silicon Carbide Paper attached to a sturdy piece of precision ground barstock. Use spray adhesive to put it on. Wear your respirator and good face protection.
With a belt on, apply the paper to the back (exposed) side of the wheel. Standing beside the machine helps. The wheel is rotating "up", so, the black dust is going to go in your face. Blow out the paper and wheel frequently-the paper will last a long time if you don't burn the grit off it from the friction.
Remember, don't let that block get away from you!!!! If you do, it'll get pulled around and break your belt and possible damage your wheel (you too)
Good luck
RJ Martin
