Contest PSK Fishing
No Chatting please; anything other than entries will be edited !
contest will run roughly a month......
Ok this Contest is a Give away of the Air Force Goof order....
Post your RP# and PSK "fishing kit" Catch.
Contest is Easy, using your PSK Fishing Kit, post a picture of your catch.
Fish, snake, turtle ,boot whatever, Spring is upon us and Good PSK Fishing time is here. Mods here will chose a winner, Prize: one of the AF mis-ordered ESEE3 knives.
Ahahahaha, if I can stop giggling like a school girl for a minute I will tell the story and upload pics....
Alright. When I read this thread I was just about to head out to my grandmother's lake and check on a possible fatwood stump. It was starting to rain so I had to scoot. I grabbed my little minimalist fishing kit on the way out.
I thought I'd try to catch a couple perch or bluegill before it started raining.
My old kit was bare bones, a few small hooks in some tape, assorted split shot weights, a couple small jig heads and some rubber grub bodies and a couple small floats (one of which isn't in the kit picture, I dropped it between the seats when I was opening it :D) Then I just had a small amount of 6 lb mono taped up so it didn't unravel.
I tied a loop in the end and tied it on my left wrist so I didn't lose the whole works. I was fishing similar to using a fly rod, just without the rod! I was actually casting by lasso throwing the line and I could get all the way to the end of my line on a throw, which was about 25-30 feet. I would loosely let the line run through my right hand and pulled it in with my left, letting it dangle at my feet, again, as with a fly rod.
Here you can see the green float out there. I had to use 2 floats because I was throwing against a breeze and needed extra weight, but didn't want to weight the jig down any more with split shot.
As I was bringing it in on the 10 or 12th cast, the float ducked and popped back up. Then BOOM! I set the hook, knew I had him and started reeling in line and backing up. I was expecting to see a bluegill, but nope here comes a bass head. For reference the RC-3 is 8" long. If I was starving to death this little kit may have saved my life.
Too bad I have my eyes closed in this pic and look like I'm crapping a RAT Pack knife. Grrrrrrr!
Great contest idea Tony, I have not had this much fun fishing in YEARS! I am going to make a better fishing kit because I learned a few things. But the lasso method works EXTREMELY well for casting. I was amazed. I bet the people around the lake thought I was bat-shiz crazy out there dancing around like an idiot. :D
RP# 367
i'm still new around here... but not a n00b. however i am still short on posts to get a pack number... but i expect that won't last for long.
PSK = "Pocket Survival Kit"? i.e. something that fits in an altoids tin or other packable container?
sorry, search doesn't work for me ATM. not trying to "chat", this is a question directly related to the contest.
Sorry no one has answered your question...Yes, your definition of PSK is correct.
I've got a question too...can we show what we don't catch? Just the PSK?
Are multiple entries allowed, or should I wait until the end of the month and then post my biggest fish?
Cool idea for a contest! We love to go fishing at the local pond! It's got fat little bass, and big ol' bluegill! I'll have to get some pics.
Vic
#678
Ok, Here's my first attempt.
The setting:
The equipment:
The technique:
The result:
A monster brown trout any fisherman would be proud of! Well, maybe not, but it's the first time I ever tried anything like this and I was pretty proud. I hooked another about the same size, but he came off and flopped back into the water before I could get a pic. I'm going to keep trying until I get something bigger! Good luck everybody!
RP#617
My PSK fishing kit is kept inside the handle of my HEST.
Nylon thread
hooks
sinker
The bait I sourced locally.(worms)
Cut a stick for a poll and your golden.
I managed to land 2 small trout in a very short time.
I know I wouldn't starve munching on these little guys.I released them both.The brook has been fished almost out so it needs all the help it can get.
My entry...
This was from the "Found Items" contest
I cant go fishing, so no catch.
I guess that disqualifies me, thats ok.
Im bored and I want to share.
Post lots of pics guys this is as close to "outside" that I can get to for a while.
My PSK = Gerber Multi-tool + my brain.
Found these items...
  • 3 Ft Rope (paracord)
  • Soda Can
  • 16 oz Water Bottle
  • Empty Cigarette Box
I used my EDC Gerber Multiplier for assistence.
The soda can
Remove the Tab
This going to be a fish hook...
A few snips and careful bending. This seriously has to be practiced guys!
It would be easier to heat it then bend. It will want to break otherwise!
Making the lure...
Tear a strip of shiny foil from the cig box.
Thread the hook through and add the little date code (that bright orange sticker from the bottom of the cellophane)
TA DA! (ok the picks are out of focus, Im trying to catch near-sighted fish anyhow!)
My "reel"
I used paracord for my three ft of rope had it been actual rope I would untwist it to a smaller size so this would work either way.
Using the core strands I tied them end to end. 7x3 I have about 21 ft to fish with. Tie one end on the lure. Tie a loop in the other end and put it under the cap on the water bottle. Put the cap back on. Tie the outer casing of the paracord around the neck of the bottle. Tie a loop in the other end. This will be your lanyard. Wind the fishing line around the bottle. The line can be tied around the cellphane trapping air and using it as a bobber or you can use a small piece of dry wood. The dry wood is a btter bobber for casting as it gives you the necessary weight.
To fish place the lanyard around your wrist.
Hold the bottle in your hand so the section with the line around it is in front of your fingers. Your thumb holds the line in place. Using an overhand casting motion and raise your thumb allowing the line to feed off the end of the bottle. When your done fishing, remove the cap and remove the line. Fill the bottle with water and use the lanyard to hang the bottle over a fire to boil water.
First of all, let me just say I had a lot of fun with this one. I felt very silly, but luckily I was in a place where no one else would want to go!
So, I started out by digging up some worms with a stick:
It was a nice day out and it started out as a nice little walk:
Pretty soon the trail started to get a little wet. I knew it would but this was really pretty wet:
Luckily I had my boots on. I just hoped they'd be enough:
This is my PSK fishing kit. I keep it in my pack all the time. All it has is some nice heavy line, some hooks, and a cabin creek for good measure. I did not use the cabin creek this day. I used the worms I had dug up.
So, I wrapped the line around a water bottle. (I figured I would have this on me, and would fit well in the simulation.) With the line wrapped around the bottle, you can swing the bait and hook around, then turn the bottle pointed towards the water and let her go! You can get some pretty good distance!
The first thing I caught was an inanimate object. A piece of wood with nails in it:
A good while later, the moment came! I had a live one! What could it be? I was hoping for a large mouth bass since they are fairly common back here, but alas. It was a pickerel. I really really really hate pickerel! I could definitely not live off of this, even if I had to:
Unfortunately, that was all I caught. There was no bass in my future this day. But I had a lot of fun anyway. As always one of my ESEE knives was with me. One of my Izulas. As is often the case:
I got to get out and it was a really nice day. I was standing on one of these tufts of grass! This area is large wetlands on the south end of Lake George we like to call the backwaters. It is best to go out in a canoe, and the wetlands go back a good way from the lake. I came in from the woods as you can see, deep into the backwaters. It can be pretty risky and you need to know where you're going to a certain extent so you don't sink up to your shoulders, literally! I grew up in this area and we used to come back here all the time. More often than not now I do come back here in a canoe.. You can just get at more of the good spots. Standing on these tufts of grass is like standing on a floating biomass, it takes a good bit of balance!
Thanks a lot for having this contest. Even though I felt like a fool every time I thought about what I was doing, I still had a blast. I really appreciate this forum. I am new here but don't feel like an outsider. So thanks again.
Erik RAT PACK #704
I tried fishing with the PSK this weekend but on the third cast I caught a tree. I will have to try again.
