Converted my Buck/Strider to a fixed blade
So sorry, but no pics. :o
I have an 889 with a bad lock. I'm sure Buck would replace it hassle-free if I sent it in, but it seems like this line has a higher-than-normal incidence of liner lock failures, and some people report getting replacement knives with the same problem, so I decided to "fix" it myself (hey, that's a pun!) :D
I considered drilling through the scales and liners and setting a bolt into one of the jimping notches in the spine of the balde, where it recedes down below the back of the handle, but it seemed like it would be too easy to screw up.
Instead, I fashioned a permanent LAWKS type shim that replaces the brass washer on the lock side on the knife, and curves around to buttress the liner to prevent it from moving off the tang. The other washer is also removed, and the blade tang seats directly against the liner on that side, leaving the liner lock no-where to go. The blade isn't centered in the handle, but it's not noticeable when in use, and the thumb stud/stop pin still makes ample contact on the front of both liners. I used a fender washer of the appropriate thickness from my junk box, shaped it with a bench grinder, and bent it in a vice. Took about an hour.
It's rock solid, and I can't see how it would fail short of disassembly with tools, or catastrophic parts failure, which I don't expect. I'll fashion a sheath from some kydex stock I have lying around, and it should be good to go as my tool-belt, yard-work beater. I still like the design a whole lot, and I didn't want to give up on it, so this makes the knife useful for my intended purpose.
Anyway, there it is...
Interesting. I just bought one these this past weekend. Haven't used it much yet, but the lock seems solid. I hesitated buying it because I'm not a big fan of liner locks. I'll have to keep an eye on it. I do like the blade, the balance and the feel of the handle. I'll keep your fix in mind. Thanks for sharing.
Terry
I wish ya had a pic :(
The 889SBMF I have has been with me every day since I got it. I always carry two Buck knives. The 889 has always been one of the two.
No lock problem at all.
That being said, I have two 889LE knives. One was a failure out of the box that I fixed. The other was spot on.
I should have pics up tomorrow. It's kind of crude, but the visual helps, I know.
I'm thinking now about what to do if/when blade play develops, since the shim piece nearly presses the lock against the opposite liner already. The easiest route would be to add very thin shim stock between the stop pins and the front of the liners. That could be done many times as the mating surfaces wear, and would probably never deflect the blade from the handle enough to matter.
What's the second EDC? I like my 889SBMF, solid sturdy knife... locks up great.
What's the second EDC? ...
Varies...
I have the following in EDC rotation depending on what's going on or how I feel:
Folder:
298GY ATS34 (2nd favorite folder after my 889SBMF...or maybe a tie for 1st)
112 Wally World
110 BG-42
110DM Damascus in for Muskrat facelift
172 Mayo TNT
110AG
889LE (formal events)
Fixed:
105 (favorite fixed blade)
119
120
124
271
890
Sounds interesting Boing. Look forward to seeing the pics.
What a variety for EDC Goose! To be honest I didn't know you liked the 889 so much as to be your primary EDC. That's quite an endorsement!
Here's the best pic I could get. I couldn't get the pivot unscrewed to pull the shim piece out, but you get the idea.
