Hello all I've recently bought a work sharp knife and tool sharpener because I don't have much sharpening experience and I absolutely love it! So I'm curious how a convex edge should be manetand? Steel? Stone? Strop? Thanks for the help I really appreciate it!
What is this "maintenance" that you speak of?
You "should" do what you know how that works for you or makes you happy
I do a full sharpening each time, takes less than 5 min from start to finish
freehand, at 10dps , on a stone, fast scrubbing passes
ends up convexed from 10dps to 11dps or 12, depending on how fast I go and how hard I press
using light force
then I deburr at 30dps or higher (4 pps)
then I microbevel at 15dps (10pps)
then I deburr at 30dps or higher (4pps)
this gets me easily arm hair shaving sharp, and often face shaving sharp
if I only have under a minute to sharpen, then i'll do a few strokes on the stone
at 10dps then at microbevel angle of 15dps then check for shaving ability,
then increase by a few degrees 17dps (next time 20dps, 22, 25, 27, 30)
that usually returns some or all of the shaving ability
I find it easier to accomplish than steeling/burnishing on glass/plates
I also find it more satisfying than sandpaper strop, stropping motion is slow , with stone you can go edge leading very fast with a lot of force (using not-waterstones, like norton economy sic, dollartree alox... )
