- Feb 21, 2001
On my 25" Sirupati and Kobra I was having a hard time getting a good edge using traditional methods. I had done some serious polishing on a buffer and the edge was buffed off. Like Yvsa and others I prefer a convex edge for toughness. I was in the process of glueing some dense foam rubber (a mouse pad) to a thin board, over which I would fasten some fine sandpaper. As stated in the sharpening FAQ, the foam will "give" as you stroke the blade over the sandpaper, giving you a good convex edge. Suddenly I realized that I already had a tool backed with firm foam rubber at my disposal. I had bought an electric straight-line finishing sander at a yard sale for $10. I carefully clamped it upside down in my vise. It was shaped so that I could do that without breaking it. Then I fastened some 600 grit wet-or-dry sandpaper and turned it on. Moving the blade lightly over it just as though I was using a stone, I had a burr in just a couple of minutes. Turning it over, I lightly sharpened the other side. It should be noted that I removed very little metal. Then the paper was changed to 1500 grit and I lightly polished both edges. A couple of minutes with my leather strop loaded with white polishing compound, and I had the best convex edge that I have ever been able to produce. When I went to test it on my arm, the hair jumped off screaming at the sight of the big blade approaching!
In a few places the mirror polish was made satin where I got the angle of the blade too low, but I was able to take care of that with the strop. When I try my Kobra I'll probably start out with 1000 grit so that I take off the minimum amount of steel possible.
This method may not be for everone, but I thought It might be of interest to other novices like myself.
Steve
Steve
