The Work Sharp is a great belt sander sharpener -
I would second that recommendation -
Review -
Work Sharp (belt grinder) Knife Sharpener
However just a little clarification -
Convex edges can be:
"Zero bevel" convex - this means the edge merges continuously/seamlessly into the blade face.
or
there is a visible separate bevel - but that bevel is convex to the edge -
this may seem nit-picky/pedantic -
but a lot of regular plain bevel edges knives when sharpened on a belt sander, like the Work Sharp, are like this.
To achieve a zero bevel convex edge - would mean grinding/reducing the entire blade face to the edge -
(as opposed to sharpening only the edge and bevel).
To maintain a zero bevel convex edge for most of us normally means using sandpaper & mouse pad method -
the Work Sharp would probably work - but there is a slight possibility that it may result in a separate bevel being ground in.
Having said that - if one looks at one of the most famous and prevalent zero bevel convex edge knives - the legendary Opinel - on close examination one can see a very fine micro-bevel - so the Opinel is zero bevel - but with a very thin microbevel
Please see:
Sticky Thread:
Microbevels
If one can live with that - for any light touch ups -
then any V-hone crock-stick sharpener (like the Spyderco SharpMaker) will do to maintain that.
Hope that helps, and not too pedantic
Vincent
http://picasaweb.com/UnknownVincent?showall=true
http://UnknownVincent.Shutterfly.com
http://UnknownVT.Shutterfly.com
http://UnknownVT.multiply.com/photos
