convex edge ????
I heard something about this in another thread . I think I might wanna try it. Is it any better then a regular edge ? How many angles should I use and in what order would I make the angle .do I make the 25 angle then the 17 ?
Or do i start with the 17 then go to the 25?
Do a search and you'll find plenty of info, or you can look up Buzzbait's website and find even more.
Matt
I would be really interested if you know a maker who makes full convex blades, not just the edge, but the entire blade? This makes for one heck of a blade!! Thanks!
Kennieyk :
This is a called double beveling, or creating a secondary edge. You start out with the more acute angle, say 15 degrees and hone until it goes almost to the very edge. You then finish sharpening on the more obtuse angle, say 20.
The exact angle that are optimal depends on what is being cut, but 15 and 20 hold over a wide range of tasks and give solid cutting performance with a high durability. If the knife was more of a pure cutting tool, you might want to try 10 and 15 instead.
The more of the edge that becomes used by the more obtuse angle, the greater the durability but the lower the cutting ability and ease of sharpening.
Multi-beveling creates an edge which is slightly lower in cutting ability that uniform edged blade with one angle, but can be a lot higher in durability, and is much higher in ease of sharpening. Usually the angles are limited to two as going beyond this gives little in terms of cutting ability or durability, and it much more difficult (time consuming) to maintain.
A convex edge is similar in nature but is applied much differently. A true convex edge is easily achieved if you sharpening using a strop or anything which behaves in a simmilar manner such as sandpaper on styrofoam.
-Cliff
Hey Cliff, how and at what angle do you sharpen the multi-bevel, say 15 & 20 degree? Thanks a lot!
For light use knives I grind the primary angle basically as low as it will go which is close to five degrees usually. For heavier chopping knives it is 10-15 depending on steel and the size of the knife. This grinding is done freehand either on stones or with a belt sander depending on how much metal needs to be removed.
I usually create the secondary bevel at 22 degrees simply because that is the angle of a v-rod setup I have, 15 would be better for the lighter user knives. For machetes I freehand the secondary bevel with a file and then waterstones. This bevel is wider on the machetes than on other knives as machetes are generally softer and weaker so they need a larger secondary edge for the greater durability.
-Cliff
