- Mar 26, 2002
A good read.
http://home.nycap.rr.com/sosak/convex.htm
He starts out:
"Convex Grinds
......, it is good to also carry a larger fixed blade on longer outings. Some of the best outdoor knives have convex grinds. The following information should prove useful in deciding whether a convex ground knife is right for you.
The convex grind varies greatly from the factory grinds found on most modern day knives. Most of todays factory knives employ various primary grinds, and a v-grind edge bevel. A convex grind can either be created on the edge bevel only, or combined as the primary grind of the blade. If the entire blade is convex ground, it is usually referred to as a full convex grind. A convex grind produces a very high performance edge on a blade, while maintaining a good amount of strength. It is almost the best of both worlds."
by Bladeforums' "Buzzbait"
He also has a nice article on walking stick crafting:
http://home.nycap.rr.com/sosak/hiking/sticks.html
"......So heres my little hiking stick FAQ. It encompasses pretty much all I know and have learned about hiking sticks through the years, and tells the story of how I made mine."
He starts out:
"Convex Grinds
