Tonight I made a real honest attempt at convexing a new knife I picked up - an Opinel #6. I used wet/dry sandpaper on a mousepad method. Well actually, my 8K Shapton Pro stone came with a nice piece of protective foam which I used instead of a mouse pad. I started things off at 400 grit and used very light pressure with edge trailing strokes. I made a point not to go past 400 grit until I absolutely felt the burr on both sides a couple of times. Anyway, I progressed up to 2000 grit using wet dry and then all the way up to 12K using micromesh sandpaper and was pretty happy with the results but not ecstatic. Gave the blade a good stropping and I can slice paper easily and shave hair.
As this was my first honest attempt at producing a convex edge I started to question whether or not it was worth the hassle since the blade is so darn thin that it would probably slice anything in the kitchen even with a utility edge. Also, since I opted for the Opinel #6 with a walnut handle, the only steel that was available in that configuration was stainless. My Opinel #8 is carbon and I would have loved it if Opinel made a #6 carbon with walnut handles. Anyways, I feel the edge could be better but I'm wondering if I'm butting up against the limit of attainable sharpness for stainless. In any case I'm questioning my convex sharpening skills. At the higher grit levels I honestly couldn't tell if I was producing an even burr. So I counted strokes and made sure I spent a good amount of time on each side before doing the other side and then moving onto the next grit. Can anyone chime in with any tips? I started with the blade flat against the sandpaper and then used edge trailing strokes and lifted up until I felt a bit of resistance. Logic tells me that the resistance is the edge of the knife hitting the sandpaper so I have a question. Should my stroke be lowered so that it feels smooth with absolutly no feeling of resistance from the edge or should the "feel" include some resistance?
Convex sharpening always seemed difficult since you are using a surface with some flex and I have a hard time imagining how a sharp non-rounded edge was even possible when compared to sharpening a knife on a hard flat surface where the bevel is in constant contact with the abrasive. Am I looking at this logically?
Here's the knife. Pic isn't the best as the front of the knife looks like it wasn't honed correctly but it is truly convex along the entire length.
