- Feb 4, 1999
I do occasional convex grinding on my Coote. My problem is that the center portion of the knife (about 1/4" on 1" wie stock, or 1/2" on 1.25" wide stock) doesn't seem to get ground. I've played with grinding closer to the platen, closer to the idle wheel, etc and that doesn't seem to effect it much. If I really push hard, I get lots of metal being removed from the edges of the belt but the center section still pretty much is untouched. "Rolling" the blade doesn't seem to help much, either. Changing belt speed doesn't matter, either. This is 1/8" thick stock, too, if it matters (which maybe it does). My questions:
1) Is this normal?
2) Is this a belt stiffness problem? (I use the regular 3M stiff belts up to 220 then switch to the really thin, flexible Klingspors after that).
3) Is this a belt tension problem? If so, too much or too little (I am using the same setup I would use for platen grinding, only I'm grinding in the space between the top of the platen and the idle wheel, which is about 1' or a little more of space)
Thanks!
1) Is this normal?
Thanks!
