- Jul 28, 2010
Which is the better edge to have on a fixed blade hunting/survival knife ? tactical folder ? Convex or V edge ?
From what I've heard, if you can put a convex edge on a knife and maintain it, it's generally superior to a v-grind. That said, most knives are sharpened with a v-grind and they might be simpler to maintain in most cases.
The smooth geometry of a convex edge cuts better than a V bevel. I don't see how that can be argued.
For someone that uses a knife often and finds themselves away from home using the knife it is definitely easier to maintain the convex edge because you don't need to carry around jigs or fixtures.
You can put everything that you need to maintain a convex edge in your wallet.
It is about impossible to have a true V bevel with hand sharpening ....... it will eventually become convexed.
The wide bevel of a Scadi grind allows it to be sharpened easier and they cut incredible in most materials because they come to such a thin edge.
That's also myth. All you need to maintain a v edge or Scandi grind is some sandpaper and a flat surface. No jigs or fixtures needed. All those Finn, Saami and Laaplanders didn't carry a jig around when living in the Arctic zone.
I maintain both Scandi and convex grinds without any problems. It is really a matter of one's preference.
It doesnt really matter. The overall geometry with regard to taper, final edge angle, thickness, etc. will play a much bigger role than just "convex" or "flat". This in turn is dictated by what you want the knife to do.Which is the better edge to have on a fixed blade hunting/survival knife ? tactical folder ? Convex or V edge ?
I don't see how it can be argued either, since it doesn't. A v-bevel converted to convex cuts more easily because steel was removed to convex the edge, so it is thinner. A thinner v-bevel does the same.The smooth geometry of a convex edge cuts better than a V bevel. I don't see how that can be argued.
I can put a credit card sized sharpening plate in my wallet, or some sandpaper. I can maintain a v-bevel with it.
Scandi grinds do not have thinner edges than v-bevels with the same final included angle. In fact, the v-bevel knife is thinner behind the edge because the primary bevel is much more acute.
Tf the two edges are the same thickness with different geometry behind them, then they do not have the same sharpening angle. A convex grind is thinner than a v-bevel for the same final included angle. That is the difference.I disagree.
I never mentioned converting a V to convex.
If two edges are basically the same thickness .... the shoulder of the V bevel impedes the cut more than the smooth transition of the convex geometry.
Don't think that you really read what I wrote either.
Yeah, your V bevel is easy to maintain with your sharpening plate but being that you cant hold it perfectly flat you no longer have a true V bevel.
It will slowly become convexed.
I do agree with your comment about the scandi though.
