I agree with the majority here, convex is a good edge, at least give it a try before you put a flat bevel on it. I've been a fan of the convex grind for a long time, really nice cutter, especially for a thickish utility blade, super easy to maintain, and has a lot of support behind the edge. For simple sharpening you can't beat a mouse pad glued to a block of wood, with some sandpaper over it. My standard convex sharpening jig has a mouse pad, split in half to go one on each side, with a different grit on each. I usually use about a 320 grit for course and a 600 for fine. It's not a super polished edge but it cuts like the dickens and takes just a few minutes to hone back to shaving sharp from fairly dull/well used. Great woodworking edge in particular, and good for field dressing and food prep as well.
Don't get me wrong, if you love a v bevel go for it, but really you should give the convex a try. You might end up convexing alot of your other blades.
And while it would work, a sharpmaker would probably take a bit to remove enough steel to get good flats for the v grind. I'd probably go for a diamond or a course stone to take most of the meat off, then go to the sharpmaker to refine the bevel and put the secondary, final bevel on.
Good luck, the Barkies are good knives with a convex or not, youy'll like it.
Syn
