- May 18, 2008
I have tried various sharpening methods, and I am currently working on getting my freehand convexing technique better.
I have been able to get a burr going using traditional v-edge sharpening using a japanese water stone and a DMT aligner to keep the angle. I also have the DMT aligner diamond stones that fit into the guide and can get a burr that way as well. Both of these methods use an edge leading stroke (cutting into the stone)
With the convexing method I place the strip of sandpaper onto the stiff leather (it is not soft) and I use an edge trailing stroke. I can see my angle is correct with a sharpie and I examine the edge with a loupe and see it is a fine edge with no defects. I have never been able to feel a burr with this technique however.
My progression with SiC wet/dry sandpaper:
220 grit: 30 strokes per side (alternating 10 strokes each side)
320 grit: 30 strokes per side (alternating 10 strokes each side)
400 grit: 30 strokes per side (alternating 10 strokes each side)
1000 grit: 30 strokes per side (alternating 10 strokes each side)
2000 grit: 20 strokes per side (alternating 10 strokes each side)
Then I move to loaded strops:
Black Compound: 30 strokes per side (alternating 10 strokes each side)
White Compound:20 strokes per side (alternating 10 strokes each side)
Green Compound: 20 strokes per side (alternating 10 strokes each side)
Bare Leather: 5 strokes per side
Steels I have sharpened using this method:
Becker 1095CV - got this sharp, but need to spend more time on it
Mora 1095 - this was the sharpest, the Scandi grind really helped keep my angle steady
GEC 1095 - the small blade makes it difficult to keep my angle constant
GEC O1 - larger blade, but still hard to keep the angle
Boker 1085 (soft steel)
Buck 420HC
Usually the angle is about 40 degrees inclusive
I am able to get a highly polished edge that can shave arm hair, but it is not quite as sharp as I have been able to achieve with a guided v-edge system (hair whittling).
Do you usually see a burr form when you are convex sharpening?
Buck 420HC
