Richard , you grind free hand as far as I know and edge up ? When you approach to belly and tip you pull/twist little tang towards you , right ? Rubber belt on rotary platen would twist when you put pressure on left or right side of belt .How much will twist depend from how tight is belt and between which two wheels you grind . When you approach belly and tip IF you pull tang down /instead of towards yourself/ pressure would stay in middle of belt and belt would not twist .But that is little tricky to do , at least to me .I don't think I'd do it that way. I did a couple convex recently and found that I twist the blade around quite a bit to keep the belt running straight over the edge, approaching the tip.
Ok , but that don t change anything ? You grind as I described , right ? Rubber belt twist and you must twist the blade more when you get to belly and tip .....Sorry, for convex I go edge down.
Thanks my friend . But most credit goes to my jig and contact wheel I use . Especially the wheel , I think .Because here in Macedonia I can't get anything knife equipment related I have to manage the way I know and can .And this time I hit it right in the centerIf I was able to do do such nice hollow grinds as you do, Natlek, I would never even consider doing convex...
