After attempting to convex my ratmandu using the sandpaper method, I finally gave up several hours later. I was going to go out and get the paper wheels at the local woodcraft as I already have a grinder. A few days prior to doing so, I stopped in to visit my parents and realized my father has 2 of the Kalamazoo 1x42's in his shop that I now have permission to use. I practiced on some old really damaged knives and a cheap cold steel heavy machete on some worn 80 grit (only belt I had at the time) and got fairly comfortable using the sander.
I've read that I can get the leather belts from Lee Valley, but what belt grits do should I purchase in addition to this and where should I look for the finer grits on x-type?
Secondly and this may seem really dumb, but I'll readily admit to being very new to sharpening. I purchased a dull hatchet and was reading how to sharpen hatchets and axes and came across this link:
http://www.youtube.com/watch?v=CKpsFLNvTD4
I may be off, but the hatchet was essentially convex? So, I started with an arkansas stone I had and went to sharpening the hatchet in the circular motion demonstrated above and it sharpened right up, then I wrapped some 400 grit wet/dry around a block I had laying around, then to 600 and then 1500 using the same motion. Finally I stropped it to polish it up and was sharp enough to shave with. Could this same method be used for sharpening convexed knives? I'm thinking it might be handy in the field.
