nozh2002
BANNED
- Jun 9, 2003
I found rust on one of my favorite knife I start using in kitchen lately. I clean rust with dremel - it was not deep fortunately and decide to try etch it in Sprite(tm) as I did before after reading it on some Russian knife forum- once blade is cleaned already. I soap it a lot and clean with rubbing alcohol, run to the 7/11 for Sprite.
It is boring to wait over night so I tried to speed it up heating - usual way to make chemical reaction run faster. In result I get perfect speed - it is not as fast as in acid oe with electro etching, and not as slow as over night, it is like cooking speed. Just turn on the heat do not make it boil shake blade time to time and in ten minutes it will have deep gray color.
video - http://www.youtube.com/watch?v=fzZicf6Z5zc
I did not wipe blade out right away, I let it dry and then apply carnauba, let it dry again and then rub. Here it is wit same blade on different knife.
I am not sure how long it will stay and how good it will prevent steel from corrosion, but this cooking blade in Sprite was fun.
This is carbon steel (Krupp?) Progressive Tempered Lauri blades with 64HRC on the edge from www.brisa.fi and I made handles myself.
Thanks, Vassili.
P.S. I am pretty sure that this will not work on stainless blades.
Thanks, Vassili.
