- Feb 11, 2008
this is my new nixon october limited with horween leather band. it also has some small changes from the other versions like the silver hands and casing ( which they now make available on their black rubber band version ) it uses swiss quartz movement. the watch is modeled after old WW1 and WW2 watches used my submariners
Movement: Swiss made ISA quartz 3 hand with large date and customized crown and date 9 hour placement.
Dial: The dial is surrounded by a custom injection molded rubber dial ring and seconds track
Case: 48.5 mm, 300 meter/ 30ATM custom sandwich construction solid stainless steel case with sandblast finish, a fixed solid stainless steel bezel, domed hardened mineral crystal with antiglare treatment on the underside of the crystal, solid stainless steel triple gasket screw down crown with a custom molded rubber insert, stainless steel screw down caseback and solid stainless steel continuous bar lugs for added strength.
