What am I missing here?
3/16 + 3/16 for the threaded part, + enough wood for the shoulder + 1/8 for the tang. That ends up being 3/4 plus a little so the bolts don't show, which is on the thick side for most any knife handle.
I guess I could trim some off the threaded part.
Andy
If you really want a headache, put these on a tapered tang.![]()
No, I know that part. I'm talking about fitting the Corby's so they're not too long at the butt end of the knife, keeping the different sized pieces separate. Just a lot to keep up with for my little brain, lol.DO check the depth of the female with a toothpick or something. I've come across some that were drilled much deeper than needed... grinding them flush and coming into a ragged hole in the middle will make you say bad words... you can guess how I found that out.
Tapered tangs are no problem - just drill the tang while still flat, taper it, and drill the scales while they're clamped onto it and the whole thing is vised and/or shimmed so the centerline of the blade is perpendicular to the drill. It's harder to describe than it is to do.
Has anyone ever had a problem with either peened or unpeened simple pins coming loose on a handle that's been epoxied?
In my experience the only time simple pins have allowed the handle to come apart has been with thin blade stock where the tang flexes or when a knife has been put in a dishwasher (you just can't hammer "no dishwasher" into some thick skulls).
I feel compelled to mention this yet again... I view epoxy as mostly a sealant, and rely on mechanical means to hold my knives together. The right adhesive for the materials used can be extremely strong by itself! But I prefer using both methods whenever possible. Under-promise and over-build.Unpeened pins....yes, and that's why I only use corby bolts any more.
Randy, you're over-thinking it a little. It's an easy matter to grind down the male/female parts to the length you need, and to drill the overbore in the scales to the correct depth. Measure twice, cut/drill once.
