cord wrap?
Can you cord wrap a carbon steel blade without water and moisture getting down under the cord and rusting the tang. How would you clean the tang after use to remove moisture under the cord. Also can you effectively cordwrap a skeleton handle and have the cord going through the holes so you can see the design when done. I was thinking about a thin coat of epoxy when done so removing the cord to clean would not be an option. Cory
