The edge is convexed from CRK so you need to flaten that out first and/or rebevel the blade to match the angle if you want to use a system of some sort to work on a factory edge. I hate sharpening systems and feel every one should learn to sharpen free hand, it's so much easier.:thumbup:
Yes sharpening systems are for nerdy, precise, and technical edge; and yes, convex is probably more traditional, a better skill to have, and easier for an experienced sharpener. I Have no trouble with either and pros and cons of both are discussed elsewhere. I will just say this. I HIGHLY recommend that your first try at sharpening by hand is NOT on CRK or any other expensive knife, as there is a learning curve!
My new small, 2012 version, fit the 15 degree angle on the Sharpmaker, except for the tip, which was between 15 and 20. About 10 swipes on the diamond rods and the tip was at 15 degrees as well.
In contast to Haze, I sharpen freehand and with the sharpmaker, and find the sharpmaker easier. I sharpen freehand when I want a convex edge, or with certain knives just for fun. I also don't think that "every one should learn to sharpen free hand". Some people just don't have the eye, fine motor skills, patience, or understanding to sharpen free hand. It's kind of like sharpening a pencil, you can do it free hand, but it's easier to use a pencil sharpener and most usually get a better result.
