corrosion protection in a marine environment
I work in the maritime industry and the knives I carry daily, primarily my Leatherman Surge & BM Grip, are showing some small amounts of rust. I know I need to keep them oiled well but in the case of the Leatherman the rust is showing on the handle(scales?) as well as the tools. How can I keep my EDC work knives coated to protect from rust without an oily residue making the scales slippery?
I use to use car ignition sealer spray on my tools, it`s a clear plasticy here is what the tin says.
Description
Sealed With A Tsss Ignition Sealer is a damp start product which waterproofs auto electrics, giving the entire ignition and electrical system a clear coat of durable plastic insulation which resists condensation, water, petrol, diesel and oil.
John.
Marine tuff cloth. Apply it. Let it dry. Buff it off. Do that several times and the last time do not buff it. Leave it on. Do this regularly and you should be much better off. It is not a 100% magic solution but nothing is. You will need to do some regular maintenance no matter what.
My two favorites are Fluid Film and Eezox. Fluid Film for larger tools and Eezox for knives and multi-tools.
The issue with Leatherman tools and corrosion appears much to do with the brushed finish most of their tools come with. I reside in what could be considered a hot and perpetually humid climate, with a lot of exposure to salt spray. My full-size Victorinox multi-tools with their more polished handles and smoothly finished individual tools have proven to be nearly impervious to corrosion as compared to my Leatherman Wave and Surge.
You did not state how you carry your knife and multi-tool. If you are carrying them close to your body or even in a pants pocket, understand that human sweat is comparable to seawater in inducing corrosion, and that most common protective coatings you might apply, be they oils, greases or waxes may be quickly rubbed off or worn away in a pocket. Clear spray lacquer, paint, or some other air-drying finish would last longer, but I don't sense you want to go that route.
If you happen to be relying on leather sheaths, then you might consider replacing them with sheaths or pouches made of less hygroscopic materials such as Kydex or some other comparable hard plastic. An advantage to these synthetic materials is they can be readily rinsed off in tap water and quickly dried should they become exposed to salt spray or seawater.
But really, the simplest and single best thing you can do is to remove your knife and multi-tool from your pocket or sheaths at the end of each day. Even if you don't bother to wipe them down with a rag infused with a superior gun oil like G96 Synthetic, just having them air-dry will do much to avert rust and corrosion.
First off, thanks for the replies every one. It looks like I have some research to do.
I do not know about rust resistant tools, but Boye makes Stellite knives for sailors that cannot rust. The blades are marked BDC (boye Dendritic Cobalt).View attachment 734980
I have had my eye on them for a while now. At some point I will pull the trigger on one of these and likely also a Salt model from Spydie as well as a Yachtsman knife from Grohmann.
I carry it on my belt in the standard sheath that it came with and some days I sweat like its pouring rain and others not so much, depends on humidity and how much work I have to do. I have never been a fan of kydex, I much prefer either leather or nylon, just seems more like what a knife sheath should be made of to me (have no idea why, just some preconceived notion in my head I guess). Thanks for the reply tho.
many points have been addressed very nicely, on those...
1. Leatherman, Gerber and SOG tools are known for being prone to rust and quick oxidation in saline environments or when subjected to sweat. The recommendation of coating them with oil or some other substance is a temporary measure, but in the end the steel will pit and rust, not damaging the tool any further if you take care of it, and clean it often
2. The solution to that problem is simple: get a Victorinox multitool. Either the Spirit or Swisstool have much better corrosion resistance -very very hard to make that shiny coating rust- and offer similar or equal strength to that of the Surge.
If the toolset satisfies your needs, they are the way to go.
3. The folder thing is also simple. Unless you are dead-set on the Griptillian, you can get for lower price an Spyderco Salt knife, the Pacific being the most similar and appropriate option.
They are grippy and the FRN is also a type of plastic that ensures good purchase and durability while reducing weight.
All the knife is completely impervious to rust and H! is excellent holding an edge in its Serrated Edge configuration. Can't go wrong with it for use near the sea, or when sweat is constantly a problem
  • Like
Reactions: whp
Yet another vote for the H1 line of knives. That is what they are made for. Other then camping in rain now and then, I don't spend mcuh time in a maritime environment so I'm not up to date on how to protect knives. Good luck.
