Cobalt
Platinum Member
- Dec 23, 1998
The following involves a question to ALL manufacturers using coatings on their blades.
Are the coatings used on YOUR knives highly corrosion resistant or not?
First of all, lets set some parameters. A good corrosion resistant coating has to be a VAPOR BARRIER to MOISTURE. There is no way around this. If your coating does not provide a vapor barrier to moisture, then it does not provide significant corrosion resistance. A good example of this is Hard Chrome and other hard metal coatings(like Ti) that offer excellent abrasion resistance but only a slight benefit in corrosion resistance. On the other hand, coatings like Walter Birdsong's coating offer a considerable amount of corrosion resistance since they are a vapor barrier to moisture. I'm pretty sure that REKAT uses Birdsongs coating.
So what is yours, TOP's, Busse, Livesay, etc., etc., etc.???????
PS: This is not a Mad Dog slam thread so let's not go down that path. There are many good coatings out there and I would like to know what is being used on current knives.
